new build - which transformers and choke?
All about iron and copper.
ChuckLogan
Great Info - -I have a question
Post by ChuckLogan » Wed Aug 09, 2006 12:40 pm
I am building a JTM50 which is tube rectified. If I want the B+ voltage to
be 385 what factor would I use to allow for the tube vs diode rectifier?
ie what multiplier can be used for Tube rectified amps . . I am aware that the voltage can vary by using different classes of tube recs
Cheers
darkbluemurder
Post by darkbluemurder » Fri Aug 18, 2006 7:08 pm
5150loveeddie wrote:A 3H will be dirtier sounding and going cleaner with more Henries, I think 7H is a nice "in between", it will be a little tighter also, one thing to really consider here the dc resistance specs, I'd go with a 300ohms around there, not those 100ohms or lower ones.......
What are you looking for in general? A gain monster?
So is it the more Henries it has the cleaner it gets?
