Hey guys. I'm looking to replace the OT, PT and choke in my 2008 JCM 2000 - DSL 100. I know there are several vendors I can use: MM, Heyboer, Classictone.
But Hammond http://www.hammondmfg.com/guitarLinePWR.htm has a line of Marshall replacement OT's, PT's and chokes as well. But, I don't see anything in their Marshall line for the JCM 2000 DSL-100 series.
Question: Would either of these 2 sets of PT's, OT's and choke work for the DSL 100 series amps?
— I don't know what the stock OT and PT's are rated for?
Hammond Power Transformers—they carry 2 - 100 watt versions:
290HX: JCM 800 & JMP - 100 watt
PRIMARY:120/220/240 VAC—50/60 Hz.
URL for specs in PDF: http://www.hammondmfg.com/pdf/EDB290HX.pdf
290JX: JCM 900 - 100 watt
120/240 VAC—50/60 Hz.
URL for specs in PDF: http://www.hammondmfg.com/pdf/EDB290JX.pdf
Hammond Output Transformers —they carry 2 - 100 watt versions:
1750U: JMP, JCM 800
Primary (Ohms): 1,700 C.T.
URL for specs in PDF: http://www.hammondmfg.com/pdf/EDB1750U.pdf
1750X: JCM 900
Primary (Ohms): 126, 500, 2,000
URL for specs in PDF: http://www.hammondmfg.com/pdf/EDB1750X.pdf
194C Choke Marshall JCM 800
Inductance 40 H
URL for specs in PDF: http://www.hammondmfg.com/pdf/EDB194C.pdf
Any help would be greatly appreciated. Thanks.
Current Marshall OT,PT & Choke Replacements
Re: Current Marshall OT,PT & Choke Replacements
try a 3h choke, not a 40h
Roe, what about the OT & PT?
Any ideas? Thanks.
Any ideas? Thanks.
Hi Maltone,
We offer a drop-in replacement for the OT in our 40-18055 at ClassicTone.
We also offer the 3 Hy choke that Roe mentions here.
Please see following:
http://www.classictone.net/40-18055.html" onclick="window.open(this.href);return false;
http://www.classictone.net/40-18058.html" onclick="window.open(this.href);return false;
Also, we have a PT in development now for the 100W JCM2000 DSL amps and should be available in a few weeks.
Thanks,
ClassicTone By Magnetic Components, Inc.
http://www.classictone.net" onclick="window.open(this.href);return false;
Thanks,
I'd second the classictone transformers
I 3rd that.
