JCM800 choke vs. Marstran 3H C1999 audio clip test
I hope I didn't mess up the recording process because these two sound way more different then I was expecting. From what I read, both are 3H chokes, so they should perform VERY close... not to mention why would something as simple as a choke make this much difference?
First the lick and chords twice with one choke, then the same licks/chords twice with the second choke:
http://tylergrund.com/mp3/choketest.mp3" onclick="window.open(this.href);return false;
I'll tell you guys which choke was which after a few listens. BTW, just for reference, the JCM800 choke came from http://www.tubesandmore.com" onclick="window.open(this.href);return false; and is the direct marshall JCM800 replacement choke. if that helps.
(now keep in mind the marstran is brand new and needs to break in a bit more for sure!)
- syscokid
Re: JCM800 choke vs. Marstran 3H C1999 audio clip test
For what it's worth...I felt the 2nd half of the clip had a more pronounced, snappier bottom end.
I just love snappy, bottom ends....
"When I'm on stage and first plug in, and I feel a rush of air in my balls... That's when I know my guitar is sounding good!" -Leslie West
- darkbluemurder
I have not yet heard the samples but I experienced that a choke can make a notable difference - on two of my amps it made a bigger difference than changing the output transformer.Gamedojo wrote:I hope I didn't mess up the recording process because these two sound way more different then I was expecting. From what I read, both are 3H chokes, so they should perform VERY close... not to mention why would something as simple as a choke make this much difference?
- 77custom
I like the throatiness in the first 1/2, and I really like the clarity in the 2nd 1/2. Too bad we couldn't have both together!
So, which choke is which?
I like the first one best
Metroamp builds : 68` 50w (x2), 69` 100w, 68` 100w 12xxx (x3), JTM45/100, JTM50(x2), 2203
1st one sounds more vintage to my ears
- StuntDouble
I like the 2nd half the best; it's more chimey and open. So which is which?
I liked the first one. The second sounded a little harsher to me.
First one seemed pretty tight, second rounder with a vintage chime.
Made me realize I could live with either one. So which is witch?
- StuntDouble
What has it been sinc3e you posted this, a year and a half? I think it's tim e to spill the beans.
- 77custom
StuntDouble wrote:What has it been sinc3e you posted this, a year and a half? I think it's tim e to spill the beans.
I concur!! Spill the beans sir!
So sorry guys! I totally forgot I even posted this. Honestly, I'm having a tough time remembering, but I think the JCM800 was FIRST and the Marstran was SECOND.
The simple reason was that I remember my initial reaction when I made the switch. I lost some warmth with the Marstran, but gained clarity in the notes.
Again, sorry, totally forgot to post.
- chrisom
The first is not bad, but the second one sounded nicer to my ears for the type of playing and sound you had dialed in.
