Mercury Magnetics O100JM-SL question
All about iron and copper.
satino
Post by satino » Tue Jul 24, 2007 5:36 pm
i am about to wire the impatence switch and the Brown ,Black, Yellow and Green wires all have to two leads and there is nothing in the instrustions for 100w kit about this what do i do? twist them together or cut one off?? help :(
novosibir
Post by novosibir » Tue Jul 24, 2007 8:51 pm
You must not twist it, but you have to solder each both together to the selector's lug, otherwise the secondary will be interrupted!
Larry
satino
thanks
Post by satino » Wed Jul 25, 2007 12:02 am
thanks Larry i just wired it up! the black 4 ohm was pretty thick! :)
2308to
Post by 2308to » Mon Jul 30, 2007 4:52 pm
novosibir wrote:You must not twist it, but you have to solder each both together to the selector's lug, otherwise the secondary will be interrupted!
Larry
I am curious to understand why not to twist the secondary OT wires? I've many speaker cabinets with the inside wires twisted for the speaker hook ups.
