Hello,
I have an Axiom MP-100-460 power transformer and want to verify a few connections:
First, I assume the browns are not used.
The Blue/White and Grey are twisted together and go to standby.
The yellow goes to filter cap. What does the yellow do?
Orange goes to main fuse
Red goes to power switch.
Thanks,
Dave
Mercury Magnetics wiring question
- novosibir
That seems to be another color code:
http://forum.metroamp.com/download.php?id=3182
If you'd mention ALL the colors on your PT, thinghs would go easier!
Larry
Larry
good points
right, sorry I didn't provide proper info. Larry's link to the diagram is basically what I have, though mine has 9v ACC brown wires.
So I'm basically sure that this is correct, but I was hoping someone could verify the following:
that the brown 9v acc wires are ignored
that the 175 B+ get twisted together and go to standby switch
that the B+ center tap (yellow) goes to positive terminals of filter cap
and that orange (common goes to mains fuse).
thanks,
Dave
thanks,
Dave
- VelvetGeorge
- Site Owner
