Metro Jam for the Listening
- St August
Well Heres the results .....
http://www.soundclick.com/util/getplaye ... 51378&q=hi
Intro-----VG
1st solo----VG
2nd solo----St.A
3rd solo---Flames1950 ( Mr Reverb Wink )
4th solo---45Auto
5th solo---tonejones
6th solo---NitroLiq
7th solo---St A
8th solo---JimiJames
9th solo---Chief
10th solo---Flames1950
12th solo----NitroLiq
13th solo---tonejones
14th solo---Nitroliq
ending solos---JimiJames/St.A AND HARMONY BACKINGS
All solos are right up the Middle it just sounded better that way.. I want to Thank all of you for participating.. Everybody brings something different to the table and all was good.. Alittle old and a little new, some kind of clean
some kind of distorted.. I wish more would have participated but maybe the next time.. I really enjoyed doing this its a great way to relax. Its been a pleasure working with all of you, all great guitarist in your own right...or a Legend in your own minds ...lol you choose.....lol
Intro-----VG
1st solo----VG
2nd solo----St.A
4th solo---45Auto
6th solo---NitroLiq
7th solo---St A
9th solo---Chief
- St August
Jackson Soloist
Miller Retro Valve 50 w Rocco Mod
4x12 w/25watt greenbacks close mic with Sennhiser E609
and I know how to use the Whammy
- NY Chief
- Wiki Editor
- Flames1950
My first clip was my '96 LP Studio, with a HighOrder 8.3K AlNiCo2 in the bridge slot and a HighOrder 7.6K AlNiCo3 in the neck, 500K CTS pots with Auricap .022uF's done in vintage wiring..........no pedals.
My Metro '66 JTM45/100 clone, with all carbon comp resistors (the noise was starting to come around after sitting cranked for a while!) original SoZo's, BC electrolytics, George's trannies, PEC pots........tubes were a Brimar ECC83 in V1, Telefunken ECC83's in V2 and V3, GT KT66HP's biased at 28-29mA, 530VDC on the plates............Ran unattenuated into both my 4x12's, the close-miked speaker was a Weber 30-watt Silver Bell, the mike sitting back further would have captured the Bells and the '94 Greenback RI's (2 of each in the miked cab.) Close miking was a Shure SM57, further back a CAD condenser I used for drum overheads.
Guitar settings were everything on ten, bridge pickup of course. Harmony guitars found the amp set at presence 3, bass 3, middle 7, treble 6, Volume I 8.5, Volume II at 4, plugged into the Channel I high input only (no jumper.) The second part of the track got a bump in the presence to 5.5-6, and Volume I on 10, everything else was the same (mic placement changed thanks to my son Jakey.)
Second clip was the same guitar, same cab mic'ed but the 57 was back about a foot because I wasn't capturing any highs up close.........Super PA settings were presence 6.5, bass 2.5, mids 8, treble 6.5, Normal Vol.1 on 10, all three other volumes on 5 to cut down on highs bleeding into the other channels....no jumpering though. That amp had Brimar ECC83's in V1 and V2, Telefunkens in V3 and V4, the new Tung-Sol KT66's at about 525VDC on the plates, again at about 28-29mA. Marstran 1202-84 clone output tranny, and the Marstran 20H RS clone choke, power tranny is George's Metro 1204-43 clone. George custom made the boards, I loaded them with NOS carbon comps all around and NOS Mustards; BC electrolytics, PEC pots. The clip does not do the sound of this amp justice though.
- Flames1950
- 62sg
6th & 12th solo - 80s Ibanez RG470 with a SD JB in the bridge position...running through a *cough*Johnson J-station amp modeler*cough*...some kind of "plexi" settings I dialed in...bit of dly, verb, and compression.
14th solo - same basic j-station patch with a slow phase added. Stock Les Paul Standard this time.
The 6th solo is basically an early bad take of me trying to get the 14th solo down. I had given up on it because I wasn't feeling it so submitted the 12th solo as the "real" one. When Jerry asked me to do another one, I did the 14th solo...in like 10 minutes....I guess it's true what they say...if it's not happening, take a break and come back to it.
Anyways, great jamming with everyone. I'm up for another one...blues are fine with me. This time I'll actually use an amp.
- St August
Flames1950 wrote:My first clip was my '96 LP Studio, with a HighOrder 8.3K AlNiCo2 in the bridge slot and a HighOrder 7.6K AlNiCo3 in the neck, 500K CTS pots with Auricap .022uF's done in vintage wiring..........no pedals.
Damn Andy write abook why dont ya!
Also I would like Thank to those who wanted to participate and for some reason couldnt ..At least there enthusiasm was there...
WE ARE ALL METROSTARS
- 45auto
very cool dudes! we should do more of this...
are we listing our gear used? ibanez rgt3120, dod preamp, metro 12k, 4x12 full of nasty old 75 watters...rock on brethren! 57 close at an angle to mid cone into cubase sx2 pc
- 45auto
damn... forgot about that. it was a snarling dogs wah.
- VelvetGeorge
- Site Owner
- tonejones
Schecter Blackjack Tempest w/ highorders (11.8 k bridge) on 1st solo, w/ coil tap on for 2nd solo.....
'69 clone, Heyboer PT, OEI OT, 3.3H MM choke, 1st generation Sozo caps, no bright cap, PPIMV, no presence circuit (ppimv 5, bass 5, mid 4, treble 5, channel vol.
.....boosted w/TS-5 soundtank (tone 0, level 10, dist. 5) thru Avatar 212 w/v30 Eminence......
You guys jam!!!!
You guys jam!!!!
- JimiJames
- NY Chief
- Wiki Editor
