Multi-amp and DRY Wet setups using what I have..
- mightymike
..Until I get a power amp and PC7O and run a separate wet dry
I never use my 67 SUper Reverb anymore, and I'd like to run it in a multiamp setup with a Half Stack Plexi. When I've done this before, there have been some noise problems. It's probably becuase of the proximity of the amps to each other, where I was standing/facing , the way I had them hooked up, which was with the Y that came with my Swamp ASH/KOA/Maple Neck HSS Custom Shop Brian Moore. At the time I was running the Piezo Side to The Super Reverb, and the regular pickups to the Plexi. It was fun for a while, but the novelty has worn off, and I would really like to just go with the regular magnetic pickups to both amps, daisy chained, Dry On the Plexi side cept for a Normaly Off Phaser In Front (for occasional Rush or VH). reverb on 3 on the SR. I could put my TMB in front of the SR too. Haven't Decided which Delay (rack or Pedal) To go with, and where to put it, but it will be normally off as well. I usually play pretty dry. The dynamics almost have a chorus like effect, so I don't anticipate ever needing a chorus.
I was hoping that daisy chaining might help with noise verses the Y method, but will the First amp color the tone? Also isn't daisy chaining done by brdging the channels, Then running anothwer cable from the hole underneath. I would think that would cause more noise problems if anything. Should I run a Common Ground from the SR Chasis and to The Plexi Chassis?
I also have a mixer and RME The multiface2.
Maybe they could go in between.
What do these guys, that have like 10 amps, do to keep down the interference.
- VelvetGeorge
- Site Owner
To do multi-amp setups well, you really need a buffer/isolation box of some sort. Someone traded me a Kendrick amp switcher a while back that works great. Check out Radial, they make lots of great pedal/amp/switching type solutions. I think there's a Peter Frampton box too.
You should be able to daisy chain two amps to good affect. Try doing like Hendrix did, with the guitar into the top left input and from the lower left input to the next amp.
Turn both amps on and measure for AC between the chassis. Or plug both into a GFI outlet and touch both. If there's a problem, the GFI should trip.
Let me know how it goes. You're into the SRV setup land now.
G
G
- mightymike
I wonder if I can use one of my pedals as a poor man's buffer/ check valve if you will.. by ptting myTMB boost or my Strobo Stomp in between the 1st and 2nd amp. Or maybe I can use the true by pass and y it before, but still have the benifit of the gate/check vavle.
I think one of them only allows flow in one directiion.
I'll have to check out that Framptone switcher.
Where's the Metro Amp switcher?
My pedals squeal when I bridge channels, but that is with channels 2 volume on. If I have Vol 2 set to 0, in a daisy chain set up, hopfully I won't have that prob again. I don't normally use Vol 2 anyways.
Thanks for the tips.
- Flames1950
Is it just chaining Marshalls and Fenders together that cause the noise problems? Cause I saw a band about a month ago, and the guitar palyer had two JTM45's chained together like George described. At first I thought it was just for looks, but the sound guy said that he was running both during the show. Kind of overkill for the venue, but it did sound full. And there were no noise issues that I could tell.
What good is my wisdom
When there are no words to say
How I feel everday ?
- MacGaden
- Wiki Editor
You have a ground loop, two grounds somewhere in your set-up.
I´ve used this in an earlier version: http://www.lehle.com/frameset.php?count ... k=products
It´s really only a transformer, but it has to be a good one. Maybe someone here can advice ?
And I have had good results live and in the studio with this:
http://www.hughes-and-kettner.com/produ ... rod&id=110
Ran it to the mixer, to add effects. Kept a mike on the speaker at the same time. In smaller places I just used the red box to the mixer for stereo effects.
MacG.
- Flames1950
If all you want is a switcher, the DIY A/B switch on Fulltone's website works very well, and has never caused me noise problems. But daisy chaining the amps together seems to cause lots of ground loop problems; the switcher never did, even though you'd think the signal grounds and amp grounds would be similarly coupled........even a good stereo chorus may buffer things enough to split the signal without problems if you've got one to try (it would be one of the few uses I have for one .)
I have an older version of the Red Box from my last band, sounded OK if your sound wasn't terribly bright, but much better with some mic in there.
- rockstah
i used to have the red box - sounded pretty decent from what i rememberFlames1950 wrote:If all you want is a switcher, the DIY A/B switch on Fulltone's website works very well, and has never caused me noise problems. But daisy chaining the amps together seems to cause lots of ground loop problems; the switcher never did, even though you'd think the signal grounds and amp grounds would be similarly coupled........even a good stereo chorus may buffer things enough to split the signal without problems if you've got one to try (it would be one of the few uses I have for one .)
- Flames1950
- rockstah
- Flames1950
Back to subject, I don't think I had near as many noise issues running two Marshalls together as a Marshall and a Fender. Maybe it was because my Fenders still have the polarity switches hooked up even with a three-prong cord (I know, I know ) thus causing different ground potentials or something..........
- mightymike
What about a marhall and a Power amp in a rack for the second cab?
Also can I make that poweramp serve double duty as a PA, as well as be for the second Marshall wet Cab, or do I have to get separate power amps?
I'm looking at Poweramps right now trying to decide which way I'm going to go. I have an 8 space rackmount case with Soundcrfaft Mixer on a slant on top, with a Furman Power Conditioner, and RME Multiface 2
that goes to my laptop.
(So 5 spaces will be available after I get a PCM 70
The Goal being: Porta Studio/PA/Wet Dry Guitar rig in a box to along side my Half Stack cranked and attenuated to usually -12db
- JasonC
