Lexicon Omega,Lambda or Alpha Desktop recording units
T.J.Fuller
Post by T.J.Fuller » Thu Oct 18, 2007 7:18 pm
Does anyone have any experience with either of these units?
Any pros or cons about either of them is appreciated.
Also, would these units be compatable with Adobe Audtion???
Thanks, in advance!
"In search of World Class Tone"
Clips - http://www.soundclick.com/tjfuller" onclick="window.open(this.href);return false;
http://www.myspace.com/tjfullerproject" onclick="window.open(this.href);return false;
St August
Post by St August » Thu Oct 18, 2007 7:41 pm
These are both firewire or Usb interfaces with a couple of mic pre's right..
Should not be a problem with Audition..
How ever I would reccomend getting a firewire interface. They have less problems with latency and dont require as much resorsces from your cpu to operate...
T.J.Fuller
Post by T.J.Fuller » Thu Oct 18, 2007 7:56 pm
I think they are USB, I'll look a little deeper
They claim to to be Zero latency thru the USB?
This is why I'm inquiring...I'm reading reviews that say both good and bad things and it's making it tough to make an informed decision.
If firewire is the way to go, is there anything else you recomend??
St August
Post by St August » Thu Oct 18, 2007 8:56 pm
I guess it all depends on how much you want to spend :wink:
RME, Audiofire 12 or 8, Presonus, M-Box, Focusrite Saffire all fire wire check them all out..
I use a RME Hammerfall I bought off off VG very nice interface 8 in 8 out
Real Nice converters very clean..
T.J.Fuller
Post by T.J.Fuller » Thu Oct 18, 2007 10:11 pm
thanks Jerry for the other possible options
I'll do some homework on those you listed.
may have some questions later
thanks again!
St August
Post by St August » Thu Oct 18, 2007 10:34 pm
Right On :wink:
