question about reamping
- npminard
Is it correct if you run your amp>load>effects>power amp>cab? I know it probably wouldn't be called reamping anymore (and also a dumb question), but can you take out the power amp from the chain and run amp>load>effects>cab? Not sure if that would even work or not, don't want to try it in case it's not good. Thanks
- 45auto
correct. but no, you couldn't really go fx straight to the cab without an amp to bring your signal up.
- miguel
i think it would be a rather quiet setup.
I recently revamped my live rig - I've got the amp running into a loadbox, with the slave output from the amp going straight to the power amp & cab. The cab is miked with a Sennheiser e906, and that dry signal goes to a line mixer, where it is split to a stereo f/x processor and everything (including my piezo acoustic signal) gets mixed down to a stereo house send.
Very cool sound in the house and in my in-ear monitors.
"Put your message in a modem and throw it in the Cyber Sea"
- npminard
- miguel
