Changing the speaker cloth on a 4x12
cary chilton
Post by cary chilton » Wed Dec 06, 2006 2:46 pm
Is this easy or not?
I want to put in the salt and pepper cloth....
master keeper
Post by master keeper » Wed Dec 06, 2006 2:57 pm
There was a post on this over at the gear page in the amps and cabs forum!
62sg
Re: Changing the speaker cloth on a 4x12
Post by 62sg » Wed Dec 06, 2006 3:51 pm
cary chilton wrote:Is this easy or not?
If you are the adventurous hands on type... it's not too bad. You need to remove all of the old staples that held the old cloth.
Keep in mind that snp is very thick, and can be difficult and frustrating to work with for 1st timers. Alignment of cloth to baffle board is essential, and keeping it there is critical when stapling the 1st side. And be prepared to use many staples.
A home made stretcher is what I use for getting the cloth straight and tight.
(82.85 KiB) Downloaded 372 times
JOHN
Scumback Speakers
Supporting Advertiser
Post by Scumback Speakers » Wed Dec 06, 2006 4:03 pm
It just takes patience. Here's the grillcloth tutorial I did...hope it helps.
http://www.thegearpage.net/board/showthread.php?t=67452
Post by yngwie308 » Mon Dec 11, 2006 7:00 pm
Music Ground told me that they reverse the grill cloth on their cabs for a better appearance,this they had done on my salt and pepper 1982 stack I bought from them sight unseen in the '90's.
novosibir
Post by novosibir » Tue Dec 12, 2006 3:04 am
62sg wrote:A home made stretcher is what I use for getting the cloth straight and tight.
What is a home made stretcher?
Larry
62sg
Post by 62sg » Tue Dec 12, 2006 4:20 pm
Larry
Basically a piece of wood with the loose, opposite end of the cloth stapled to it. {the 1st side of cloth is already lined up and stapled to baffle]
Wrap it around the inside of the baffle, and use the wood for leverage to get the cloth straight and tight. Does take patience and practice.
JOHN
