43v on pin 5s
3v on all my heaters
PT is at frigin 499 plates
biased to about 33mA
I'd have to change the bias range resistor to go lower.
I initially thought I blew a speaker, because the bottom end falls apart unless you have the amp heavily atenuated at bedroom level. The sound is like like motor boating through a speaker with a hole in it. Right now it sounds like ass compared to my aluminum 12000.
going over my work.
and wondering if higher rated CC 100ks on v1 and v2 are causing this.
They're all in the 114 to 117 range.
5150LoveEddie was saying something about not going overboard on the off values with 100ks, so that's where I'll start I guess. Is this what you experienced?
