help me choose a variac
- rockstah
i guess i need 10 amp at least for my purpose.
ill be installing a seperate heater transformer and variacing the whole amp.
anyone have one ideas on the one i should get?
hows this? http://www.mcminone.com/product.asp?cat ... d=72%2D110
Mark
Mark
- guitar007
- 5150loveeddie
WHy you want one Mark??
- 5150loveeddie
AH ok, good idea!! Where are you gonna get the heater transformer?rockstah wrote:why else man? with a seperate heater tranny and variac the rest of the amp my friend.5150loveeddie wrote:WHy you want one Mark??
- rockstah
well i just back from radio shack and all they have are 12.v transformers so im looking.5150loveeddie wrote:AH ok, good idea!! Where are you gonna get the heater transformer?rockstah wrote:why else man? with a seperate heater tranny and variac the rest of the amp my friend.5150loveeddie wrote:WHy you want one Mark??
- 5150loveeddie
It will smooth out things, I've tried it before, I use my variac at 115 right know so I get around 445-450 on the B+ with ****** PT, it smooths out everything....and my heaters are around 5.9/6.0 VAC so I guess its not so bad for the tube shredding....
- rockstah
i hear ya - ill put in a transformer so i get constant 6.3vac on them heaters.5150loveeddie wrote:It will smooth out things, I've tried it before, I use my variac at 115 right know so I get around 445-450 on the B+ with ****** PT, it smooths out everything....and my heaters are around 5.9/6.0 VAC so I guess its not so bad for the tube shredding....
- Tone Slinger
- rockstah
i will be using the 500dcv tap and bringing it down to 90volts or where ever i have to go with it to get the B+ around 460 dcv.Tone Slinger wrote:Hi guy's just wonderin if any one could describe to me what the sound and feel difference would be between using the variac like Rockstah (anti cathode stripping way) and one of George's voltage dropping power transformer's would be ? Has anyone done/got both ?
- 5150loveeddie
But ****** has that (460) or is it an other PT here?rockstah wrote:i will be using the 500dcv tap and bringing it down to 90volts or where ever i have to go with it to get the B+ around 460 dcv.Tone Slinger wrote:Hi guy's just wonderin if any one could describe to me what the sound and feel difference would be between using the variac like Rockstah (anti cathode stripping way) and one of George's voltage dropping power transformer's would be ? Has anyone done/got both ?
- rockstah
georges dual tap.5150loveeddie wrote:But ****** has that (460) or is it an other PT here?rockstah wrote:i will be using the 500dcv tap and bringing it down to 90volts or where ever i have to go with it to get the B+ around 460 dcv.Tone Slinger wrote:Hi guy's just wonderin if any one could describe to me what the sound and feel difference would be between using the variac like Rockstah (anti cathode stripping way) and one of George's voltage dropping power transformer's would be ? Has anyone done/got both ?
- 5150loveeddie
okey
Re: help me choose a variac
http://cgi.ebay.com/VARIAC-FOR-TUBE-AUD ... dZViewItemrockstah wrote:i guess i need 10 amp at least for my purpose.
Mark
- rockstah
expensive little bugger!RACKDOCTOR wrote:http://cgi.ebay.com/VARIAC-FOR-TUBE-AUD ... dZViewItemrockstah wrote:i guess i need 10 amp at least for my purpose.
Mark
