Speaker comparison for EVH tone.
Ok, in an attempt to nail the EVH tone I'm trying out several different speakers and need your opinions on which comes closest. In the recording below the first track is a G12M Greenback reissue, then G12H30 reissue and then an Eminence Private Jack. I'm recording with Wolfgang (CC pickup) into Flanger, into EP3, into Plexi clone (MM OT) into cab, SM57 into mixer into computer. I added a touch of plate reverb from Cool Edit. They all sound pretty similar. Opinions?
Here the link: http://www.mp3lizard.com/download.cfm?id=20873
Plexi Clone (MM OT, Sozo+ Caps)
Wolfgang Special with CustomCustom bridge
EP3 Echoplex
MXR Reissue Flanger, Phase 90, 6-band EQ
Ruby Tubes 2X12 with G12H30's, G12M's
Boss GE-10
EP3 Echoplex
Boss GE-10
MY WEBSITE: http://www.rubenhoeke.com
FACEBOOK: http://www.facebook.com/profile.php?id= ... ef=tn_tnmn
i like the second one the best!
My EVH sound clips.
My EVH sound clips.
I've got this posted over at the PlexiPalace site also and it seems the general consensus is the reissue greenback comes the closest. I bought the G12H30's because Mojave uses them in their cabs and assumed the reissue 30's nailed VH the best because thats the tone they try to emulate. I just wish the greenbacks could handle a little more power. I think the Private Jacks roll off treble the most IMHO.
EP3 Echoplex
Boss GE-10
EP3 Echoplex
Boss GE-10
to me the greenback clip is too bright and harsh.do you have basket weave grill cloth across your speaker cabinet?that rolls some highs,and may be the problem!
My EVH sound clips.
My EVH sound clips.
- 908ssp
The buzzy highs also has to do with fact that I recorded at low volume using the RichMod PPIV master volume. When I crank it the highs roll off a bit. Yeah the reissue greenback are very bright IMO.
EP3 Echoplex
Boss GE-10
EP3 Echoplex
Boss GE-10
The first one sounded closest. However your reverb sounds more like a delay than a reverb IMO.
James
James
Cheers to the ears.
the delay sound is my echoplex, I added just a touch of reverb using Cool edit pro. The problem with the reverb is that it brightens and sterilizes the sound some what. I mistakenly recorded the tracks at bedroom level, should have cranked the amp thru my Mass 150 to cut the brittle highs. I might re-record tracks with knowledge learned.
EP3 Echoplex
Boss GE-10
EP3 Echoplex
Boss GE-10
- mightymike
I went back and forth between your three versions and the original, and I thought 2 was the closest.
IMHO you need some smoothing of the high end.
First place I would look at is mic placement, and are you clipping into the sound card? No amber or red, just green on your meter right? If you have the mic straight in, try it at a 45, and see if it smooths out the over all tone.
What Tubes are you using can affect this.
Also BW will help with this, but it will roll off some high too.
You can lay a thin towel over the front to experiment.
Keep up the good work.
Edit.. I see you recorded at bedroom level. You got to crank it.
I put the cab in the closet, put the mic to it, and surround it with pillows
to keep the DB down so I can hear the backing track through the headphones.
You can also clone the dry track, onto another track, and only apply the reverb to one, and then mix and eq it in so that it stay closer to the original tone. This will also give the feel of 2 mics.
I also have an EP3, and bridge it betwen the channels on my plexi, so that I can adjust the wetness, without affecting the tightness.
LOL sounds like foreplay
It is if you think about it.
Just some ideas
Take it for what its worth.
Just some ideas
- rgalpin
second cut sounded the best to me. i thought the greenbacks were the worst of the 3 because the intense briteness.
the forst thing i thought of when i heard the greenbacks is - he's got the same problem i do!
that brittle attack gets all in the way of the beef and cream.
i have v30s - it was suggested that they are a part of my briteness problem - but i'm not sure what to try - i might have to look into what you used there in cut 2. thanks man.
- rockstah
with all due respect - and i mean that - you guys r nuts here - the voice of the first take is it if anything of the 3 for vh - r u saying you like the sound of the second take? - ok - i can dig it but its not the VH voice - no way jose- the midrange of a v30 is always apparent and always is not vh - come on! listen to the voice not the sound.
