jnew
Post
by jnew » Thu Dec 25, 2014 11:54 am
Finally received the 68K Iskra's and put them in. The amp now has maybe 20-25 hours on it and I think it's burning in quite VH II ish like. I'm loving it. Share your thoughts.
http://www.soundclick.com/bands/page_so ... D=13007844
jnew on Sun Dec 28, 2014 3:38 pm, edited 1 time in total.
Star*Guitar
Post
by Star*Guitar » Thu Dec 25, 2014 9:35 pm
The tone is killer!! But the guitar is out of tune.. Lol
Star*Guitar
jnew
Post
by jnew » Thu Dec 25, 2014 9:47 pm
It is?
I thought I had it but those 3 note chords in the chorus always throw me. The B string has to be pulled sharp with the pointer finger while the D string has to be slightly pushed sharp for these chords to sound right so I may have been listen too closely at those to realize the rest of the stuff was actually off. But I'm still not quite catching it. Is my track flat?
Star*Guitar
Post
by Star*Guitar » Fri Dec 26, 2014 6:57 am
Somethings off intonation or recorded track?
Star*Guitar
jnew
Post
by jnew » Fri Dec 26, 2014 11:12 am
Might be a good time to focus on how to accurately intonate a guitar but I don't know if it is truly possible. Seems every guitar I've ever owned has a little something here or there that sets up slightly different from one to the next. I've had many many many guitars and I don't think one has ever been a perfect instrument as far as tuning goes. They just don't. You set up the intonation, get all the open chords tuned right and the more complex chords higher up are out. You get those right and the open stuff is whack. Guitars are fussy little fu#$%ers.
Star*Guitar
Post
by Star*Guitar » Fri Dec 26, 2014 4:31 pm
A good internet bud, Chip Todd , who worked for Peavey for many years and designed the T-60 taught me a slightly different way to intonate at guitar. He explained that simply playing an open note and 12th fret harmonic wasn't enough to calibrate a string at all frequencies, his method was;
Open string -12 fret harmonic,
Third fret, then try to use the same finger pressure and sound the note on the 15th fret, then the
5th fret, then compare the note on the 17th fret using the same finger pressure....and so on.
Once all strings run true, and the notes on each string match an octave using the same string pressure...Its ready to go.
I've had great success that way.
Star*Guitar
jnew
Post
by jnew » Fri Dec 26, 2014 8:27 pm
OK. I just put on some new strings and went through it like you said. I think it is better. Will try a re-take and see how it goes. Using .009's this time. Had Hybrid .009's/.010's before.
jnew
Post
by jnew » Sat Dec 27, 2014 2:40 am
I think this one is better tuned but the low E has nasty fret buzz. Lighter gauge doesn't pull as much bow in the neck so I have a little buzzing going on. Will fix that next. Also made the track louder.
jnew on Sun Dec 28, 2014 3:39 pm, edited 1 time in total.
Strat78
Post
by Strat78 » Sat Dec 27, 2014 4:26 pm
Can't separate the original track from your track, ugh, where are those headphones!
jnew
Post
by jnew » Sat Dec 27, 2014 4:33 pm
Really? They're pretty much 100% on opposite sides and I have mine louder. My amp's on the right if you're speakers are arranged accordingly.
rgorke
Post
by rgorke » Sat Dec 27, 2014 10:46 pm
Regardless of any tuning issues, the amp sounds great.
jnew
Post
by jnew » Sun Dec 28, 2014 12:08 am
Thanks Roger. Having good holiday's in CA?
rgorke
Post
by rgorke » Sun Dec 28, 2014 1:16 am
jnew
Post
by jnew » Sun Dec 28, 2014 12:39 pm
jnew
Post
by jnew » Sun Dec 28, 2014 3:37 pm
Ok. Last take on this. Got the right chords. Like Roger said though, this is more about the amp tone than the playing although playing it wrong sure doesn't do any justice.
Editing links above.
