Slaved clip on halloween with Jnew
- Jeremy1283
http://www.soundclick.com/bands/page_so ... D=12957533
I think I have reached a good point with my setup. Head back in head cab.
What do you guys think?
- rgorke
Re: Slaved clip on halloween with Jnew
That sounds really good. How loud was that? Is it slaved into the front of another amp or a power amp?Jeremy1283 wrote:http://www.soundclick.com/bands/page_so ... D=12957533
- Jeremy1283
It was pretty quiet.
Chain went. Guitar-ep3-amp-load-lineout-peavey 50/50 -4 12 with the scumback pvc
75s.
75s.
- Jeremy1283
It sounds even better in the room!
- Strat78
Thats it, you are there!
The amp is a little more burned in by now, but also, what were the last changes you made? Those chords are some of the sweetest I've heard. That is a 12xxx in the true form!
- Tone Slinger
Sounded excellent
Whats the circuit specs you ended up with ? What r u using for the load/line out ?
- Mr.Farva
Sounds excellent!
What pickup, amp settings, and how much is the ep3 turned up?
- efraser68
Yes sounds good Jeremy! The low E is nice and tight and the amp's got some good saturation.
- Jeremy1283
Thanks man.. That means allot coming from you phil.Strat78 wrote:Thats it, you are there!The amp is a little more burned in by now, but also, what were the last changes you made? Those chords are some of the sweetest I've heard. That is a 12xxx in the true form!
switched:
32 to a 100 in Phase inverter
100k on the 4 ohm which doesnt do justice till you put the 100 uf for the phase inverter cap.
took fat cap off
changed out mustards for philips style caps on the .68 spots
kept the filtering at 16 for the pre amps using those nos eries I had.
Changed to rifa for the screens.
also variaced yo 90 with two tubes pulled which is great cause a quad will last that much longer.
I THINK THAT IS IT. LOL
for the load its a resistor load. then a separate lineout box james built..
- Jeremy1283
Thanks everyone for checking it out. If it wasn't for james and you good people id still be lost.
- Jeremy1283
It was a duncan custom
Pup. Scumback speakers
- Tone Slinger
Again, really nice. Reminds me of Efrasers and Kev's tone alot. Definately hear that distinct vowel type inflection that is great and synonymous to reamping
What volume did you have the 100 watter (running at 50 watts
) at ?
- Jeremy1283
The vol. on the head was at 6 and more and the head falls apart. Its perfect at that vol with the variac at 90 and the built in variac switch on the low setting. LolTone Slinger wrote:Again, really nice. Reminds me of Efrasers and Kev's tone alot. Definately hear that distinct vowel type inflection that is great and synonymous to reampingWhat volume did you have the 100 watter (running at 50 watts
) at ?
- Tone Slinger
Cool ! So you have a dual tap PT, and your running the lower voltage tap of it, via the three way standby switch (virtual variac). That along with the variac slightly taking it down a hair.. So what did your actual plate voltage end up being ? You could have just ran the high tap and lowered everything just a tad more, via the variac, right.
- Strat78
At this point you could even dial in a little more bass or bring in a little of the normal channel a bit (without jumping you still get a little roundness added with that knob). Keep your mitts out of that amp now
, it's all about how you run it: guitars, pickups, V1 NOS 12ax7's, cable lengths or even try a variac between the head and the cab, it adds some interesting hair! Great job again, maybe you will inspire Tone Slinger and others to get building again!
Love these amps!
