******'s Mod
Jeremy1283
******'s Mod
Post by Jeremy1283 » Tue Sep 09, 2014 5:15 pm
I found this looking on the internet. Is it true that this was done on the first album? :scratch:
http://www.twistyneck.net/cm.html
I am still learning so please be patient. :worthy:
rgorke
Re: ******'s Mod
Post by rgorke » Wed Sep 10, 2014 9:51 am
Jeremy1283 wrote: Is it true that this was done on the first album? :scratch:
IMO, not likely. But there are many opinions.
mr.twistyneck
Re: ******'s Mod
Post by mr.twistyneck » Wed Sep 10, 2014 11:34 am
Agree. All first album theories are just - theories.
I like the C****m's Mod Theory, but my guess is that *perhaps* it was tried and then probably discarded due to non-scalability.
I like the Secret Pedal Theory - that's gotten a lot of people *really* close. The nice thing about the SPT is that there are many ways to goose the front end of an amp, and as a result there have been many great results using many different setups.
For example:
I'm The One using a Throbak Overdrive Boost and a 6 band MXR EQ, mixed in with the band: http://www.twistyneck.net/twangedband08 ... twisty.mp3
On Fire using the same setup: http://www.twistyneck.net/twistyOF08141 ... eqverb.mp3
******'s Mod demo'd live, skipped to the actual sound: http://www.youtube.com/watch?feature=pl ... pE0#t=232s
Re: ******'s Mod
Post by VelvetGeorge » Wed Sep 10, 2014 12:27 pm
There's always the theory that it's his stock plexi, variac'ed down to around 90V AC. EQ'ed on the console, slamming tape and compressed with a Urei limiter at mixdown. But that's no fun.
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 12:39 pm
VelvetGeorge wrote:There's always the theory that it's his stock plexi, variac'ed down to around 90V AC. EQ'ed on the console, slamming tape and compressed with a Urei limiter at mixdown. But that's no fun.
https://www.youtube.com/watch?v=gBSoD0d6N_w
This is a 1976 recording. :scratch:
Re: ******'s Mod
Post by VelvetGeorge » Wed Sep 10, 2014 12:54 pm
Great clip!
Nothing more than dimed plexi level of gain there IMO. There is some mid focus going on, might be an EQ pedal I guess, or just as likely: the mic was positioned over the cone of the speaker, rather than the dust cap.
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 1:51 pm
VelvetGeorge wrote:Great clip!
Then variaced down to control the volume? That is where in confused. His tone is killer and its not that loud.
mr.twistyneck
Re: ******'s Mod
Post by mr.twistyneck » Wed Sep 10, 2014 2:59 pm
Hard to say exactly what he was using on this particular clip, or what his actual stage volume was. Agree with George that it sounds mostly like a dimed amp.
Using a Variac to just lower the input voltage doesn't do much to lower the volume IMHO - even if you're at 90 volts. I think - and don't quote me - that some have used Variacs for attenutation in between the head and the cab, but I don't recall hearing examples.
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 3:05 pm
What tubes will stand up to variacing down to 90 volts and cranking the bias.. will the6ac7? the new ones
How long do the tubes last if you keep thi setup? 10 hrs or am I wrong :whistle:
rgorke
Re: ******'s Mod
Post by rgorke » Wed Sep 10, 2014 4:10 pm
Jeremy1283 wrote:What tubes will stand up to variacing down to 90 volts and cranking the bias.. will the6ac7? the new ones
IME, variacing down has a huge impact on volume. Been using the same Sylvania 6CA7s for about 4 years.
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 4:21 pm
Thats killer man
those are the real deal tubes? Where can i get a quad of them?
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 5:09 pm
I think i will order a quad of new 6ca7s and see how long i get out of variacing them down. I play 4 hrs shows each weekend so i will just bring a backup head. Should be interesting:)
The chase continues. Lol
emmjaydubya
Re: ******'s Mod
Post by emmjaydubya » Wed Sep 10, 2014 6:44 pm
rgorke wrote:IME, variacing down has a huge impact on volume. Been using the same Sylvania 6CA7s for about 4 years.
Agreed, it brings the volume down quite a bit. I just biased my amp for 105v just a week ago after having it at 90v for a year and a half. Noticeably louder with more clarity (headroom) and not quite as much compression and sag. The EH 6CA7 quad has been fine at 90v for that long, no hiccups at all. Besides, they're just tubes. If they fail, you replace 'em! (unless they're Sylvanias! :shock: )
FYI, a dummy load in the other speaker jack will reduce volume as well. Sound will be affected, depending on load.
Jeremy1283
Re: ******'s Mod
Post by Jeremy1283 » Wed Sep 10, 2014 7:11 pm
Thanks for your input guys. ou rock!!
I am gonna order a quad of EH 6ac7 tubes.
Question how do you know what to bias the amp at with a voltage of 100 or 90?
efraser68
Re: ******'s Mod
Post by efraser68 » Wed Sep 10, 2014 9:24 pm
Twisty killing it on the clips. If I remember the sound cuts out because a compressor plugin, right?
