Ed's '1984' tour rig
- Tone Slinger
My 'International Musician and Recording World mag has the 'Music award poll' results for 1984.
Eddie Van Halen- Best guitarist
Geddy Lee- Best Bassist
Greg Hawkes (cars)- Keyboardist
Neil Peart- Best Drummer
It has info from Rudy Leiren, It alluded that for the studio (for '1984' I presume) Ed used,
A early '60's (more like late '60's) Marshall 100 watt top that was retired from roadwork 3 tours ago, due to a scare with it getting lost in air freight (we know that story). "The brain has a plastic front and back, a three way toggle switch and has been modified to run hotter".The bias has been turned up, so consequently, longtime guitar technician Robin (Rudy) Leiren supplies the Marshall with Sylvania el-34 (6ca7) tubes because they run somewhat cooler than similarly numbered tubes made by other companies.This 100 watt head sits atop a stock Marshall 4-12" cabinet housing Celestion drivers.
Van Halens effects consist of MXR's phase 90 and Flanger, an ADA preamp (used occasionally), an MXR Micro Amp (used sometimes), a Roland DC-30 (for chorusing and long ech delays) and an MXR echo unit for hints of delay. Leiren maintains that Eddie has used MXR gear ever since the first album and tour because of its affordability and durability.
It goes on to say that Eddie uses Fender XL strings (we know) and D'andrea picks (says they make Fenders picks). Says 44mm. There is also a list of the studio gear at the 5150 studio.
There is a layout of Ed's 1984 live rig. It reads,
Strat style guitar into Nady transmitter/reciever into MXR Phase 90 into MXR Flanger into 2 MXR echo units into 100 watt Marshall head into 2 H&H power heads then split into 10 2-12" custom cabinets and 2 8 - 12" custom cabinets.
There was obviously nothing said about a load box, though there obviously was one.
Also, the '100 watt Marshall head' was a nice sounding Plexi chosen for this set up (no more JMP's). I didnt get that from this article, but from another old '80's mag of mine.
Sounds like Ed had the Micro Amp in front of the head. This, imo, is correct info and is the basis for Ed to FINALLY get a good/consistant live tone again. The Letterman show, '85 Namm, Farm Aid, etc, utilized this type rig, imo.
Re: Ed's '1984' tour rig
84 is the most unlike all other vh record plain raw tones-cleaner, brighter, super tight.
- rgorke
Micro amp, huh, maybe that secret pedal hidden in the Echoplex box. These came out in the '80s though, right?Tone Slinger wrote:
Finally, can you scan that article in so we can see....please....
- Tone Slinger
Yeah, I really dont care for the tone much on 1984. Its alright, just not my favorite. Its the tone that Ed got on that TOUR that I like. That tone was the same as what Ed got up to the Letterman stuff and NAMM '85.
LWAN was similar, but was a tad nicer, probably due to further use of effects, etc.
My wife sold the scanner without me knowing about it
. Anyone know how to get the pixel level down enough in pics to post here. I could get up a pic of it.
- Good Guest
Something lost in the transalation there..are we to assume he has a bias switch? Maybe the knob at the back is a switch....the amp running hotter may mean a od mod or one wire mod or some other mod or it may be the bias turned up makes the tubes hotter....This is the guy where info on the univox and how it is only used for eruption is to be believed ..I don't think so ...
These answers are so ambigious and vague there is no question he's beating around the bush...
Tells me there are lots of secrets still out there.
- rgorke
The more I listen to that interview with Steve Rosen, the more I just think Ed is ignorant (only meaning not knowing the exact way things work) about how a lot of stuff works and can be a bit inarticulate. Just jumbling words and phrases where the meaning could logically have 3 or 4 outcomes.Good Guest wrote:Tone Slinger wrote:
- Tone Slinger
My Metro '12xxx' series has a three way toggle switch........
http://forum.metroamp.com/viewtopic.php ... 6&p=284854" onclick="window.open(this.href);return false;
Rudy has said this to Dave.
Look there was no slaving of any amps until 1984 tour everything was in front of the amps and yes hiss Rudy Leiren told me that. Its not all that hard his signal chain into a stock Marshall with 6ca7s biased hot droped with a variac. In these pics he is using telefunken tubes that he use to buy at the tv repair store[ this was told to me by him] Dave
Very simple. Rudy leiren told me personally. Flange phase echoplex into a marshall with variac to 90 into only one cab. The univox echo or whatever was only patched into the chain for eruption he also used a eq for eruption. Eq was also occasionally used for tone shaping with amps that did not sound as good. This was the core setup. As more vol was needed more amps were added and more cabs but sill only one per amp. There really is nothing more to it. Lots of sustain and feedback from the sheer vol of it all. Now ed was always experimenting and still does to this day so there might have been some mishaps along the way like tubes melting etc. No lying just things not explained the right way out of a lack of technical knowledge.
Well here is what i was told by Rudy Leiren his long time tech. This was just last week. His setup was flanger phaser echoplex amp. His main 100 watt was used on everything. The bias was turned all the way up and the variac was set to 91v. into only 1 cab. There is a pic of the early days with a 50 watt and a vox. He told me the 50 was a back up to the 100 and the vox was a last ditch back up. He often borrowed amps for his back ups. In fact he told me a story that at a party they were playing ed blew a fuse in his main amp and did not have a backup and had to rum home to get a fuse while the band was playing. After this he always made sure he had a backup. Now Rudy said the eq pedal was used only for certain guitars or sometimes when he used rental gear that sounded bad. Also the univox echo was patched in by hand for eruption only and then was taken out of the chain after. Later there was another cab on Mike side that was driven from another amp they used a splitter to do this. As time went on more cabs where used and so where more amps. The amps would only drive one cab though. Now he did say ed was always trying shit but would always come back to this set up. This info follows everything ed has ever said to me personally. Also when 84 hit he changed his set up to H&H power amps and some different effects etc. He still used a cab off the head though no load resister. The Load resister came for the 5150 tour.
- Tone Slinger
That post established the most concrete proof of Ed's early set up/s. It does make sense to those who have done what was described. Not MANY people bludgeon 25 watters (100 watt cab) that hard with a dimed 100 watt head, which would be more like 120 watts or so dimed. Variac obviously would take that down a bit (like 70 or 75 watts or something).
Its been said here MANY times, you CANT reproduce it properly without BLASTING the speakers.
Pandora Jewelry
Pandora Charms
Pandora Bracelet
Balenciaga Shoes
Nike Shoes Canada
Adidas Canada Online Shopping
Wholesale Jordans
Pandora Jewelry
Pandora Charms
Nike Outlet
Nike Shoes Women
Moncler Outlet
Yeezy Boost 350 V2
Nike Outlet
Nike Canada
Pandora Jewelry
Pandora Jewelry
Nike Shoes For Men
Nike
Nike Store
Pandora Charms Jewelry
Nike Mens Shoes
Nike Air Jordans 1
Pandora Charms
Cheap Moncler Jackets
Pandora
Pandora Jewelry Bracelets
Jordan 1 Retro
Nike Canada Online Shopping
Pandora Jewelry
Adidas Website
Pandora Jewelry Black Friday
Pandora
Ferragamo Shoes
Nike Outlet Store
Jordan 1
Pandora Charms
Mens Adidas Shoes
Adidas Shoes
Pandora Bracelet
Balenciaga Sneakers Outlet
Nike Sneakers For Women
Adidas NMD
Asics Shoes
Pandora Outlet
Adidas Clearance
Nike Shoes
Adidas Shoes Women
Goyard Handbags
Nike Running Shoes
Pandora Outlet
Pandora Charms
Jordan 1's
Pandora Bracelet
Wholesale Jordan Shoes From China
Adidas Outlet
Nike Sneakers Men
Salvatore Ferragamo
Womens Basketball Shoes
Asics
Pandora Jewelry Official Site
Pandora Outlet Online
Pandora Jewelry
Air Jordan 1 High
Adidas
Nike Shoes Men
Pandora Charms Outlet
Puma Shoes
Nike Shoes Women
Pandora Jewelry
Nike Shoes Outlet
Adidas Sneakers For Women
Pandora Charms Sale Clearance
Nike Shoes
Goyard Bags
Pandora Charms
Nike UK
Pandora Jewelry
Moncler Jacket
Pandora Outlet
Pandora Jewelry
Pandora
Yeezy
Wholesale Jordan
Ferragamo Belt
Pandora Charms
Adidas Canada
Nike Shoes
Pandora
Air Max 270 Men
Asics Running Shoes For Women
Jordan 1 High
Jordan 1 Retro
Pandora Charms
Asics Sneakers
Pandora Bracelet Charms
Moncler Jacket
Jordans 1
Moncler Jackets
Air Jordan 1 Retro
Pandora Charms
Nike Outlet Store Online Shopping
Asics Outlet
Adidas Shoes
Asics Gel Kayano
Adidas Yeezy Canada
Ferragamo
Pandora Outlet
Air Jordan 1 Dior
Pandora Jewelry
Jordan Ones
Pandora
Moncler Sale
Pandora Rings
Asics Outlet Store Online
Moncler Jackets Outlet
Air Jordan 1 Low
Pandora Jewellery
Nike Shoes
Balenciaga
Balenciaga
Balenciagas
Ferragamo Belts
Adidas Running Shoes For Men
Yeezys
Nike
Nike Outlet Store
Pandora Charms
Adidas Shoes
Moncler Outlet
Balenciaga Triple S
Balenciaga
Pandora Charms
Pandora Jewelry
Moncler Coat
Cheap Mens Adidas Shoes
Pandora Rings
Pandora Bracelets
Jordan 1 Lows
Pandora
Pandora Charms
Pandora Bracelet
Balenciaga Shoes
Nike Shoes Canada
Wholesale Jordans
Pandora Jewelry
Pandora Charms
Nike Outlet
Nike Shoes Women
Moncler Outlet
Yeezy Boost 350 V2
Nike Outlet
Nike Canada
Pandora Jewelry
Pandora Jewelry
Nike Shoes For Men
Nike
Nike Store
Nike Mens Shoes
Nike Air Jordans 1
Pandora Charms
Pandora
Jordan 1 Retro
Pandora Jewelry
Adidas Website
Pandora
Ferragamo Shoes
Nike Outlet Store
Jordan 1
Pandora Charms
Mens Adidas Shoes
Adidas Shoes
Pandora Bracelet
Adidas NMD
Asics Shoes
Pandora Outlet
Adidas Clearance
Nike Shoes
Adidas Shoes Women
Goyard Handbags
Nike Running Shoes
Pandora Outlet
Pandora Charms
Jordan 1's
Pandora Bracelet
Adidas Outlet
Nike Sneakers Men
Salvatore Ferragamo
Asics
Pandora Jewelry
Air Jordan 1 High
Adidas
Nike Shoes Men
Puma Shoes
Nike Shoes Women
Pandora Jewelry
Nike Shoes Outlet
Nike Shoes
Goyard Bags
Pandora Charms
Nike UK
Pandora Jewelry
Moncler Jacket
Pandora Outlet
Pandora Jewelry
Pandora
Yeezy
Wholesale Jordan
Ferragamo Belt
Pandora Charms
Adidas Canada
Nike Shoes
Pandora
Air Max 270 Men
Jordan 1 High
Jordan 1 Retro
Pandora Charms
Asics Sneakers
Moncler Jacket
Jordans 1
Moncler Jackets
Air Jordan 1 Retro
Pandora Charms
Asics Outlet
Adidas Shoes
Asics Gel Kayano
Adidas Yeezy Canada
Ferragamo
Pandora Outlet
Air Jordan 1 Dior
Pandora Jewelry
Jordan Ones
Pandora
Moncler Sale
Pandora Rings
Air Jordan 1 Low
Pandora Jewellery
Nike Shoes
Balenciaga
Balenciaga
Balenciagas
Ferragamo Belts
Yeezys
Nike
Nike Outlet Store
Pandora Charms
Adidas Shoes
Moncler Outlet
Balenciaga Triple S
Balenciaga
Pandora Charms
Pandora Jewelry
Moncler Coat
Pandora Rings
Pandora Bracelets
Jordan 1 Lows
Pandora
