Have put all RWTD clips together, in the order in which they were posted
However could not capture links to:
Good Guest comparison between iso/finnished/thorny
or to Ralles clip
unimind
Celestions:
http://soundclick.com/share.cfm?id=11743045" onclick="window.open(this.href);return false;
Scorpions:
http://soundclick.com/share.cfm?id=11743458" onclick="window.open(this.href);return false;
julkke
http://dl.dropbox.com/u/49322143/evh_vs_julkke.mp3" onclick="window.open(this.href);return false;
Good Guest
http://soundclick.com/share.cfm?id=11746430" onclick="window.open(this.href);return false;
Thorny
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... 46088&q=hi
efraser68
Just amp and little verb
http://soundclick.com/share.cfm?id=11748163" onclick="window.open(this.href);return false;
Amp with Boss EQ7; frown; level up
http://soundclick.com/share.cfm?id=11748713" onclick="window.open(this.href);return false;
This clip is my Ernie Ball Axis Sport; maple neck; DiMarzio Custom Wound Pickup; BlackBack 1777 cone
http://soundclick.com/share.cfm?id=11757141" onclick="window.open(this.href);return false;
Zephyr
http://www.soundclick.com/bands/page_so" onclick="window.open(this.href);return false; ... D=11750815
rgalpin
parts-0-caster w/ hot rails bridge pup, 6 screw trem, rosewood fretboard.
http://soundclick.com/share.cfm?id=11752204" onclick="window.open(this.href);return false;
could be better for sure - but i wanted to submit the amp i'm currently working on...
oh yeah - i had to EQ the heck out of it in post to get it close enough to even post!! had to dump 10db of 1.2k with a wide cue (.68).
here is the same clip with no post production help... kinda sad.
http://soundclick.com/share.cfm?id=11752670" onclick="window.open(this.href);return false;
Thorny
http://www.soundclick.com/bands/page_so" onclick="window.open(this.href);return false; ... D=11752837
rgorke
http://soundclick.com/share.cfm?id=11754632" onclick="window.open(this.href);return false;
Good Guest
http://soundclick.com/share.cfm?id=11755515" onclick="window.open(this.href);return false;
Thorny
http://soundclick.com/share.cfm?id=11758492" onclick="window.open(this.href);return false;
Thorny
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... i&newref=1
garbeaj
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... 63388&q=hi
garbeaj
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... 63466&q=hi
TJFuller EQ'ed Thorny
http://soundclick.com/share.cfm?id=11763588" onclick="window.open(this.href);return false;
gaebeaj
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... 66870&q=hi
jimijames
http://whammybomb.com/media/RWTDMetroClip2012-7-15.wav" onclick="window.open(this.href);return false;
jimijames
http://whammybomb.com/media/RWTDMetroClip2012-7-18.wav" onclick="window.open(this.href);return false;
Thorny
http://www.soundclick.com/player/single" onclick="window.open(this.href);return false; ... 77083&q=hi
Ralle
RWTD iso.mp3
jimijames
http://whammybomb.com/media/RWTDMetroClip2012-7-22.wav" onclick="window.open(this.href);return false;
TJFuller
http://soundclick.com/share.cfm?id=11796126" onclick="window.open(this.href);return false;
RWTD clips in order of submission
Dont tell me to turn it down
Re: RWTD clips in order of submission
That's the closest one to my ears.
Detail that spec from guitar to post EQ.
- garbeaj
Be sure to post the entire link in your post...you will get a 404 if you try clicking on some of them...
Link to sample now uses speaker cab impulses through Poulin LeCab2. Plexi is dimed but recording is completely silent.
https://soundcloud.com/user790084345/vhrwtd
So you played your amp and then the VH clip with a bunch of the same post reverb?
