The Official RWTD ISO VS. YOUR CLIP thread-CLIPS ONLY!!!!
- Thorny
THIS THREAD IS FOR CLIPS ONLY!! NO FEEDBACK IN THIS THREAD PLEASE!!!
Please post feedback in the other thread titled "Official RWTD ISO VS. YOUR CLIP Feedback thread"
Here is the format.
1.Download the RWTD ISO tracks found here:
http://forum.metroamp.com/download/file.php?id=13736" onclick="window.open(this.href);return false;
http://forum.metroamp.com/download/file.php?id=13735" onclick="window.open(this.href);return false;
2. Make one mp3 consisting of the RWTD ISO immediately followed by your clip. This can easily be done in Audacity, Pro Tools, Reaper etc..
3. Submit the clip to this thread with any settings you would like to share.
Good luck!!
Here is the format.
Good luck!!
Re: The Official RWTD ISO VS. YOUR CLIP thread-CLIPS ONLY!!!
Here is my submission. Actually 2 different amps. One with Celestions and one with Peavey Scorpions (which sound more like the JBLs). In each clip Ed plays first then I follow.
Celestions:
http://soundclick.com/share.cfm?id=11743045" onclick="window.open(this.href);return false;
Scorpions:
http://soundclick.com/share.cfm?id=11743458" onclick="window.open(this.href);return false;
Celestions:
Scorpions:
I messed around with this today and this was the closest i got...
http://dl.dropbox.com/u/49322143/evh_vs_julkke.mp3" onclick="window.open(this.href);return false;
EVH first then me.
EVH first then me.
- Good Guest
Well here is my submission...jb pickup...secret pedal....Freidman spec plexi circuit ..6ca7's ...volume on 1 (low volume)
mic 4 inches away from center with sm57 any closer and low end disappears for this clip.and I didn't lower the guitar volume for the clean bit and added some reverb.
http://soundclick.com/share.cfm?id=11746430" onclick="window.open(this.href);return false;
Goodguest, what are the 3 different clips of??? I am lost. The second one, KILLER.
- Good Guest
Your not supposed to ask questions in this threadcary chilton wrote:Goodguest, what are the 3 different clips of??? I am lost. The second one, KILLER.
- Thorny
This is what I came up with and how.
Guitar-90s Japanese Fender Strat with 6 screw vintage trem and maple neck
Pickup-Dimarzio Super Distortion(newer model F spaced) 2 pennies on bass side penny and dime on treble for height
Amp-Bray 4550 plexi-1987 50 watt plexi circuit with value changes and PPIMV, no added gain stage. Amp was in tube rectifier mode(ala jtm 45). Upper left input. Everything dimed except Bass on 3. PPIMV also dimed. 8ohm(amp) to 16 ohm(cab) mismatch. Tubes are 3 JJ ecc83 s, 2 EH EL34, 1 JJ GZ34
Cab-4x12 with Chinese Greenbacks miced 1/4 from cloth, straight no angle.
First part of clip is ED then me alternating back and forth on just the riff. Then the whole Iso followed by mine.
http://www.soundclick.com/player/single ... 46088&q=hi" onclick="window.open(this.href);return false;
- garbeaj
Sounds good...best on this thread so far. May I ask if you notice a difference between the F-spaced and the Gibson spaced SD?
- efraser68
I throw my hat in the ring: Metro 12 xxx; Gibson LP with PAF; Celestion 6402
Just amp and little verb
http://soundclick.com/share.cfm?id=11748163" onclick="window.open(this.href);return false;
Amp with Boss EQ7; frown; level up
http://soundclick.com/share.cfm?id=11748713" onclick="window.open(this.href);return false;
This clip is my Ernie Ball Axis Sport; maple neck; DiMarzio Custom Wound Pickup; BlackBack 1777 cone
http://soundclick.com/share.cfm?id=11757141" onclick="window.open(this.href);return false;
- garbeaj
Way to stick in that rake behind the bridge!efraser68 wrote:I throw my hat in the ring: Metro 12 xxx; Gibson LP with PAF; Celestion 6402
- Zephyr
http://www.soundclick.com/bands/page_so ... D=11750815" onclick="window.open(this.href);return false;
It would sound better if not for soundclick's compression
- rgalpin
guitar > ep-pre > amp > cab (paralleled with a load)
SL
split 820/.68
0022 xicon
mixer 330p
v2a 820/25u
tone stack 33/560p lemco
output couplings .047u mallory
2 tubes EH6CA7
weber stan spec 2x12 w/ load in parallel
no attenuation
had to run the TREBLE on the amp at 4 to match the subdued growl of the ISO - but still i couldn't get it like i wanted... must need a component value change. or maybe it's the guitar.
parts-0-caster w/ hot rails bridge pup, 6 screw trem, rosewood fretboard.
http://soundclick.com/share.cfm?id=11752204" onclick="window.open(this.href);return false;
could be better for sure - but i wanted to submit the amp i'm currently working on...
oh yeah - i had to EQ the heck out of it in post to get it close enough to even post!!
had to dump 10db of 1.2k with a wide cue (.68).
here is the same clip with no post production help... kinda sad.
http://soundclick.com/share.cfm?id=11752670" onclick="window.open(this.href);return false;
hey guys... use the comments thread http://forum.metroamp.com/viewtopic.php?f=16&t=39284" onclick="window.open(this.href);return false; for all comments - this should be CLIPS ONLY posts.
SL
split 820/.68
0022 xicon
mixer 330p
v2a 820/25u
2 tubes EH6CA7
no attenuation
- garbeaj
Sorry! It took me a minute to read the clearly posted instructions
- Thorny
I'll let you guys decide if you think this is any closer. Everything the same on this clip except I'm using a Duncan 59.
http://www.soundclick.com/bands/page_so ... D=11752837" onclick="window.open(this.href);return false;
Sounds good Thorny, but I really can't see anyone, ever coming close to strat78's Nov27 for Runnin' or Nov16 for Little Dreamer. Crazy EVH tone!
