oh gosh dangiddit......mine has a red light......vanhalen5150 wrote:From the pics I think he has one of each.dazzlindino wrote:vanhalen5150 wrote:GG is correct. You can see the different version indicated by the front panel light so I've been told. One version has a red light and the other has a smaller silver version.
and the Van Halen correct color is?
Makes ya think doesn't it?
What happened to the 'secret' pedal thread ?
Re: What happened to the 'secret' pedal thread ?
Dont tell me to turn it down
- vanhalen5150
.rgorke wrote:I thought he was refering to cost of EC-80s going up. I just bid on one and was outbid within 10 mins, you vulchers.
I think Ben did some work with the EC-80 and didn't get too far, maybe he had the wrong type???
That being said, we have been told that the Univox was only patched in for Eruption.
- VUL.jpg (32.18 KiB) Viewed 1980 times
- guitar007
Help me understand. So the secret pedal is an EC80....neither a pedal nor a secret?? I've got 2 working units...that I'll have to spend a little more quality time with.
~guitar007
cool....let us know....mine is under technical supervision at the moment.......wahhhguitar007 wrote:Help me understand. So the secret pedal is an EC80....neither a pedal nor a secret?? I've got 2 working units...that I'll have to spend a little more quality time with.
HAAAAAAAAAAA HAA HA HA HA HA HA HA. Annnnnnnddddd THEY'RE OFF!!!
i USED to have TWO EC-80's - one working, one for parts. dumped 'em 15 years ago.
had a tube echoplex too . sold that to Sterling Ball around the same time.
Had a ColorSound Overdriver - vintage. sold that years ago on eBay for like twenty bucks.
makes me want to spit. i can solder with the best, just don't have the time. dangit. dangit. dangit.
- Good Guest
Sorta... kinda.... maybe ....guitar007 wrote:Help me understand. So the secret pedal is an EC80....neither a pedal nor a secret?? I've got 2 working units...that I'll have to spend a little more quality time with.
The EC-80A is an effect.
but it has quarter inch inputs.
and it's kinda big.
so it's like a big pedal.
a big pedal whose job was NOT overdrive, boost, distortion, gain, etc.
But - per the circuit similarities - it does do something other than just the delay effect. Probably not the design intent, but nobody was probably worried about true bypass back then, especially with a cheap tape delay that used Dictograph tape cassettes.
so it is an effect that had extra benefits other than its intended use. in theory. heh.
and it's kinda big.
Woooo..its all sooo clear.....bummer dat'....mr.twistyneck wrote:HAAAAAAAAAAA HAA HA HA HA HA HA HA. Annnnnnnddddd THEY'RE OFF!!!
it would be simple enough to change a pot and a cpl resistors / capacitors......
yep... would like to have some stuff I have let go / destroyed...who knew???....
glad to know you picked that colorful clone thingy over the other thingies that we p.m.'d about....
- Good Guest
Just get a power boost and bypass the gawd awful tone section...and boost it with a mxr 6 band ... You'll be miles ahead .
Don't feed the ebay gougers and don't even bother with the univox echo's ..there really crap units..and even crappier after decades of shelf life...
Maybe the throbucks guy has an tone control bypass switch...Twisty says there good ..they must be OK
It's all about the type of amplifier in the univox echo ....and the power boost and overdriver...that's the key thing...not the vintage quality of the parts...no mojo etc ....transistors aren't really all that important....it's the type of amp it is and I'm not gonna feed the lurking sponges with any more info...
- rgorke
Aw come on, please!!!Good Guest wrote:Just get a power boost and bypass the gawd awful tone section...and boost it with a mxr 6 band ... You'll be miles ahead .
- Spongebob.jpg (13.21 KiB) Viewed 1971 times
AWWWW SNAP!!!
Somebody get a dustpan, there's beans all over the place!!!!
good luck finding one of those for less than a grand. if at all.
- rgorke
Good thing Rockstah is banned....
- Good Guest
Such a simple little circuit ..would fit nicely in the box 1 ....without the gawd awful pedal. Jeez we should be getting evh clips all day long here.....after we scoop up all those beans..
True those things are rare rare and then rare...Jimmy page sure liked them and boy do they stick out like a sore ...I can just see EVH at a led zep concert going I want one of them tank boxs..and then stuck with the problem of hiding it.. How the hell?..well it's easy...just put in a permanent gain control..sound familliar???...Goodbye humongous tank box ..hello tiny circuit in an empty suppa fuzz container....
Good to see Vh1tone dixie....Ha from a Canuck yet..like we know the land of cotton...
We know from Rudy that Ed used a MXR EQ and the Univox EC-80 in the chain for VH1 Eruption.
I think it was something like this
Phase->MXR EQ->Univox EC-80->Echoplex->Amp
That's a EQ boost into a Colorsound like circuit for most of Eruption and then at the end the Univox delay get's switched on (probably by a footswitch).
Whether Ed had this chain for most of VH1, who knows, if someone hears the VH1 Eruption tone on all the other tracks then to their ears it would be the same setup as VH1 Eruption.
Plus there are pretty good possibilities of Ed having a compressor EP-3 Echoplex(es) and a Jose Zener Master on his main amp.
Once all these things are added up, then it's not really a case of how did Ed get his gain and sustain, but more like how could he not get his gain and sustain.
Also, the end of VH1 Eruption might even be Ed fuking around with the Univox and Echoplex delays at the same time but Ed just fuks with the Univox delay live and it never quite sounds the same as VH1.
