Page 1 of 6
Mighty Mite MFG 8.6k...
Posted: Fri Dec 16, 2011 9:10 pm
by Ralle
Is this a MM 1400? It's a black, as thick as the DSD I have... black...
Re: Mighty Mite MFG 8.6k...
Posted: Fri Dec 16, 2011 9:56 pm
by leadguy
Does it look like any of these?
Does it have Hex screws?
The Hex screw Mighty Mites came in Cream, Zebra and Black and if yours is a Hex screw Mighty Mite that measures 8.6K then I would say it's a Mighty Mite Vintage 1400.
http://forum.metroamp.com/viewtopic.php?f=16&p=222968" onclick="window.open(this.href);return false;
Posted: Fri Dec 16, 2011 11:08 pm
by Marshall SL12301
The MM 1400's read at 9.5K according to the old literature
Posted: Fri Dec 16, 2011 11:15 pm
by Marshall SL12301
Ralle wrote:Is this a MM 1400? It's a black, as thick as the DSD I have... black...
they look like this,
Posted: Fri Dec 16, 2011 11:20 pm
by Marshall SL12301
heres the one that was in the bee on VHII
Posted: Fri Dec 16, 2011 11:35 pm
by leadguy
Yeah, but they seem to vary a bit.
I think Strat78 had one which was 8.85k
http://forum.metroamp.com/viewtopic.php ... 0&p=298867" onclick="window.open(this.href);return false;
Posted: Sat Dec 17, 2011 1:05 am
by Marshall SL12301
yeah i see that can happen with pu's. according to his clip he made with the MM 1400 that was probably the pup not the MM1300.
I think this clip with a MM vintage sounds much closer to VH1 than the DSD or MM 1300 does. it has some PAF character to it whereas those other two pus(DSD and MM1300) do not!
http://soundclick.com/share.cfm?id=8843726" onclick="window.open(this.href);return false;
Posted: Sat Dec 17, 2011 7:42 am
by Ralle
leadguy wrote:Does it look like any of these?
Yes it's with hex screws, black and reads 8.6k...
Cool
Posted: Sat Dec 17, 2011 10:57 am
by Marshall SL12301
Ralle wrote:leadguy wrote:Does it look like any of these?
Cool
Ralle post some clips ASAP with that MM vintage! my vote is that is the ceramic he used in the frank when it was just black with a RW fingerboard. I really dont think he used a 13K pu on the 1st record at all, a 9K ceramic? yeah i can get on board with that
Posted: Sat Dec 17, 2011 3:38 pm
by Ralle
Marshall SL12301 wrote:Ralle wrote:Is this a MM 1400? It's a black, as thick as the DSD I have... black...
Is it still possible to buy one of these pu's?
Posted: Sat Dec 17, 2011 4:03 pm
by Marshall SL12301
Ralle wrote:Marshall SL12301 wrote:Ralle wrote:Is this a MM 1400? It's a black, as thick as the DSD I have... black...
Yes buy one of these ,
http://www.dimarzio.com/pickups/humbuck ... er/super-2" onclick="window.open(this.href);return false;
Posted: Sat Dec 17, 2011 4:08 pm
by Ralle
Is it exactly the same?
Posted: Sat Dec 17, 2011 7:32 pm
by Marshall SL12301
Ralle wrote:Is it exactly the same?
according to the info i could find mighty mite was copying dimarzios super d and super II when they offered their MM 1300/MM 1400 set. they are also know as the screamer set. LEADGUY may know about this maybe he will respond
It should be the same exact spec
I know the MM 1400 and super II both are ceramic,8.6K higher output pu's. despite the lower resistance reading they are wound to, they drive the amp as harder than other 8.5K PAF types due to the larger ceramic magnet.
Posted: Sat Dec 17, 2011 8:10 pm
by JimiJames
If I got this right, This model compliments a DSD in a neck position but, can be used for Bridge?
It's true, since 1979 and still use today, that my absolute Fav aftermarket pup is a DSD but, I have not listened to a Super2.
D's description sounds just right for the bridge. I'm using a late '90's DSD and it's not exact to the '70's I had but, it's in different guitars..... I think this is a very good choice as I will try it myself....
and I'm a picky ass MoFo in this department....
-Jimmie
Posted: Sat Dec 17, 2011 9:26 pm
by leadguy
The Mighty Mite 1400 is similar to the DiMarzio Super 2.
The Mighty Mite 1300 is similar to the DiMarzio Super Distortion.
Similar to does not mean exactly the same though.
