and a few different line-outs:
1) sah51050/Egnater line out
2) Jose line out?
3) Ralle line out
Progress so far:
The amp side of the load box is complete. NO line-out components yet.
Here you can see the amp side connections.
From the left:
1) The input from the amp's speaker out.
2) Selector to determine the load that the amp sees.
3) 16 ohm load boost. Push it to the right and the amp sees 20ohms when the selector is set for 16 ohms.
Click pic for larger view.
Gut shot! Just the load components so far. Line-out components will be added to the right side.
Match the wire colors to those on the schematic to figure out the layout.
Schematic!
Based on the 4, 8 and 16 ohm load box (version 2) from Aiken Amps
