EVH Chassis Layout
Are some these mods feisable for a jtm45??Let me redo this question can i use some of thes to give me a sother distortion Im not after the V H thing I have the wrong amp for that. just trying to smoth it out a little.Thanks .I will not hold no one responsable or blame them for me f^cking up my amp so if you know a few tweeks or a link in the forum lay it on me I have looked and looked and looked..Does no one mod these?..The pre amp is dam near dead on of the 100 watt, that I can see,,Thanks Darrell
I agree with you mark,i have said this in some of my threads about the van halen 1 sound, i use to talk to jose a couple times a month in the 80s, jose was a very nice man to talk to, jose explained to me that on van halen 1 there was no mods performed i will quote jose again " there was a overdrive-distortion pedal used i just dont know what kind it was"mods were performed on the second album a master volume was added to eds marshall plexi. Van halen 1 was more aggressive then the rest of the van halen recordings if you listen to van halen 2 that sounds more like a marshall with a master volume then van halen 1, it sounds like something was taken way with the van halen 2 recordings, less aggressive, in my opinion the thing that was taken away was a overdrive-distortion pedal.
- rockstah
so jose turned ed's amp into a 2203 then.MarkCameron wrote:Master volume... not a bias or line out. Iv seen and worked on a few Jose's with the master in that spot. Its not one of Jose's normal mods, just a simple master no push pull.awangotango wrote:wasn't that screw a simple bias adjustment, not a gain mod or MV.
Norockstah wrote:so jose turned ed's amp into a 2203 then.MarkCameron wrote:Master volume... not a bias or line out. Iv seen and worked on a few Jose's with the master in that spot. Its not one of Jose's normal mods, just a simple master no push pull.awangotango wrote:wasn't that screw a simple bias adjustment, not a gain mod or MV.
nitro wrote:I agree with you mark,i have said this in some of my threads about the van halen 1 sound, i use to talk to jose a couple times a month in the 80s, jose was a very nice man to talk to, jose explained to me that on van halen 1 there was no mods performed i will quote jose again " there was a overdrive-distortion pedal used i just dont know what kind it was"mods were performed on the second album a master volume was added to eds marshall plexi. Van halen 1 was more aggressive then the rest of the van halen recordings if you listen to van halen 2 that sounds more like a marshall with a master volume then van halen 1, it sounds like something was taken way with the van halen 2 recordings, less aggressive, in my opinion the thing that was taken away was a overdrive-distortion pedal.
VH1 is the 2 marshalls(1 as a preamp 1as poweramp this was the live set up) VH2 is just the main amp cranked up. Jose's master was there from the club days. I think it was taken out around FW tour. Jose would tell people different things too.Ill be at the amp show, Ill bring the old Jose load box. Lets hook up some Metropoulos Super Leads and... Univox echo,echoplex, MXR flanger, Phase90
- rockstah
doubtful this was post phase inverter master volume in this position.MarkCameron wrote:Norockstah wrote:so jose turned ed's amp into a 2203 then.MarkCameron wrote: Master volume... not a bias or line out. Iv seen and worked on a few Jose's with the master in that spot. Its not one of Jose's normal mods, just a simple master no push pull.
so if he added a master volume to the plexi circuit what else would it be other than prephase, cascaded ala 2203 master volume?
- Ricky Lee
Anyone seen this before? Would not the chassis be aluminum if it were from the 66 era. 67 era steel chassis?
- (530.83 KiB) Downloaded 942 times
Mark where is that master in the amps signal chain? Before or after PIMarkCameron wrote:Master volume... not a bias or line out. Iv seen and worked on a few Jose's with the master in that spot. Its not one of Jose's normal mods, just a simple master no push pull.awangotango wrote:wasn't that screw a simple bias adjustment, not a gain mod or MV.
- Grosh_Guitars
has anyone tried this mod? replacing the 820's with 1.1k resistors?
BTW those 820 ohm resistors were carbon-comp and drifted in value up about 1.1K and make the amp much more gainy and warmer, since these re-bias the 12AX7 valves in a bit more non-linear region..
Sound Clips: http://www.soundclick.com/bands/default ... tent=music" onclick="window.open(this.href);return false;
- Grosh_Guitars
really? it says. 1.1K and make the amp much more gainy and warmer, since these re-bias the 12AX7 valves in a bit more non-linearrockstah wrote:yes i have - changing from an 820 to 1k on v2 will yeild less gain - thus what he saying - browning out the sound.
so your saying less gain?
- rockstah
try it tell me what u hear.Grosh_Guitars wrote:really? it says. 1.1K and make the amp much more gainy and warmer, since these re-bias the 12AX7 valves in a bit more non-linearrockstah wrote:yes i have - changing from an 820 to 1k on v2 will yeild less gain - thus what he saying - browning out the sound.
if he means means gainy as in it gets fatter yes... but i dont hear that as gain. infact i hear less gain when upping the value here.
