Darn, I step away from the EVH stuff for 5 minutes and look what happens!! I missed all the fun (16 pages into the thread).
I stopped doing the Variac thing a couple years ago. I switched to a 50watt EVH 5153 for convenience.
That said, before that I used a Mojave Scorpion with Mod5 (still have it) and a Variac. While you loose power (and dBs) by lowering the Variac, there is a sweet spot. You gain sag and a certain cool vibe (
) as the voltage goes down, but after a bit (~75v for me) you start loosing the body and thickness of the sound. So I tended to stay around 85/90v and use the MV to fine tune things. The MXR 6band has body to itself, so maybe that would be the ticket, mine is so noisy I rarely use it ... I may have to give this another go!
--Johnny ComeLately
mr.twistyneck wrote:Tazin wrote: by Tazin » Tue Jan 13, 2015 5:12 pm
Hey Twisty, did you rebias the amp after turning the variac down to 60Vac?
Heavens no. I used a multimeter to dial in the 60volts on the Variac, then plugged everything in and let 'er rip. Amp technicians love me.
You dime the bias pot, and lower the input voltage at will ...
