Real Mod 5 pics
echoplexi1974
Re: Real Mod 5 pics
Post by echoplexi1974 » Mon Aug 03, 2015 3:23 pm
white noise wrote:
I'm pretty sure I know what the blue cap is.....
4700pf?
white noise
Re: Real Mod 5 pics
Post by white noise » Mon Aug 03, 2015 4:38 pm
echoplexi1974
Re: Real Mod 5 pics
Post by echoplexi1974 » Mon Aug 03, 2015 11:01 pm
BTW, nice clip you posted earlier Lbrown3743!!! :thumbsup:
What are the value of the white caps in the middle of the board?
Lbrown3743
Re: Real Mod 5 pics
Post by Lbrown3743 » Tue Aug 04, 2015 6:30 am
echoplexi1974 wrote:BTW, nice clip you posted earlier Lbrown3743!!! :thumbsup:
Thanks,
The white caps are .022uf's.
echoplexi1974
Re: Real Mod 5 pics
Post by echoplexi1974 » Thu Aug 06, 2015 11:04 am
Thanks for response Lbrown3743.
What is the value of the brown ohmite resistor just right of the white mallorys? I'm guessing 10k. If it is 10k, I wonder why Mark replaced the existing 10k for the ohmite 10k? :scratch:
mightymike
Re: Real Mod 5 pics
Post by mightymike » Wed Sep 09, 2015 5:38 pm
echoplexi1974 wrote:Thanks guys, I appreciate it :thumbsup: It's funny, out of all the pictures that I've seen of real mod5s (including mine) I've never seen the 25uf v2a being used. I'm not sure who came up with that mod5 component list, but it is really misleading.:
That 25uf on V2a was on the first 12000 series he ever built. (with Aluminum Metro chassis before George had 12000 kits with steel chassis). It also originally had M e r r en iron as well.That was his personal amp that he was trying different values on and discovered the Mod5 spec on that amp. You can clearly see it in the pics, and the chassis is signed by him.
If he never used that on another one, then all that means is he was tweaking to taste, and it sounded best for that amp.
It's no biggie, you can stuck 3 or 4 v2a caps in there on the ground side turret, have the other side of those caps sticking up in the air like a 4 branched tree, and use jumper clips to try each cap with guitar in hand to dial it in to what sounds best on the fly. That's an old trick.
Now riddle me this:
Let's say you had a .68uf, a 25uf, a 250uf, and a 330uf (maybe even a 470uf) sticking in the air. You were trying to use the biggest one you could without getting flub doing the jumper wire trick I just described and showed Mark when he built that amp.
Then one day you cliped the .68uf and the 330uf by accident... Or maybe the the .68uf and 470uf when you only meant to jump one.
I bet a dollar that's how that spec was stumbled upon!
Anyone recognize what I just described?
white noise
Re: Real Mod 5 pics
Post by white noise » Wed Sep 09, 2015 6:42 pm
Now riddle me this:
Mightymike,
Yes, I recognize what you described.
Anyone know what happened to that first 12000 that Mark built that you mentioned? And where are the pics of it?
I think i have to disagree a little with the "and discovered the Mod5 spec on that amp."
See post and quote from Mark : "this amp is my test bed for everything! ;)" referring to his '78 JMP MKII Superlead.
http://forum.metroamp.com/viewtopic.php?f=16&t=34956
echoplexi1974
Re: Real Mod 5 pics
Post by echoplexi1974 » Wed Sep 09, 2015 10:11 pm
I thought this is when Mark discovered the mod5 spec:
http://forum.metroamp.com/viewtopic.php?f=16&t=11926
Inside a aluminum classis? :scratch:
white noise
Re: Real Mod 5 pics
Post by white noise » Thu Sep 10, 2015 9:36 am
white noise
Re: Real Mod 5 pics
Post by white noise » Thu Sep 10, 2015 10:02 am
Important dates for Rockstah Mod 5 history:
Early 2007: Mark acquired the '78 Superlead Test Bed Amp :
http://forum.metroamp.com/viewtopic.php ... 78#p116532
May 21, 2007 plexi # 1 the mod 2 on Soundcloud:
http://www.soundclick.com/bands/default ... rentPage=5
May 21, 2007 plexi # 1 the mod 3 on Soundcloud:
http://www.soundclick.com/bands/page_so ... ID=5368093
May 21, 2007 plexi #1 & strat the mod 4 on Soundcloud:
http://www.soundclick.com/bands/page_so ... ID=5368422
May 22, 2007 plexi #1 & strat the mod 5 on Soundcloud:
http://www.soundclick.com/bands/page_so ... ID=5369443
Notice the use of the term Mod 2, Mod 3, Mod 4 and finally Mod 5 by Mark on the above post! :champ:
List of sound clips on Soundclick where Mark used his '78 Superlead with different components for tweaking the Mod 5 throughout 2007.
10/19/2008: Rockstah Domain name acquired: rockstahamps.com
03/18/2010 - website indexed: https://web.archive.org/web/20100401000 ... ahamps.com
03/11/2011 Trademark for Rockstah Mod 5 name acquired:
Word Mark ROCKSTAH MOD 5
Goods and Services IC 009. US 021 023 026 036 038. G & S: Guitar amplifiers. FIRST USE: 20070522. FIRST USE IN COMMERCE: 20080128
Standard Characters Claimed
Mark Drawing Code (4) STANDARD CHARACTER MARK
Serial Number 85317890
Filing Date May 11, 2011
Current Basis 1A
Original Filing Basis 1A
Published for Opposition October 4, 2011
Registration Number 4074022
Registration Date December 20, 2011
Owner (REGISTRANT) Abrahamian, Mark H. INDIVIDUAL UNITED STATES 1650 State Hwy 71 W Cedar Creek TEXAS 78612
Type of Mark TRADEMARK
Register PRINCIPAL
Live/Dead Indicator LIVE
From day one Mark was on the hunt for the EVH amp sound, here is a post by Mark on 9/15/2005 (looks to be his first post on Metroamp) stating: "wanting to build the greatest evh marshall" , well I think he did! :clap:
http://forum.metroamp.com/viewtopic.php ... 626#p25626
mightymike
Re: Real Mod 5 pics
Post by mightymike » Thu Sep 10, 2015 10:13 am
Now riddle me this:
Mightymike,
I wasn't saying how the Mod5 was discovered. You can see from the thread how he was trying different mods and everyone went gaga when he got to the 5th thing.
What I was talking about was how using multiple caps on V2 could have been stumbled upon using the tree tweaking trick. IIRC there's a a spec floating around (Dave F?) here that uses a 470uf and a .68uf. Or was it a 330uf and a .68uf? I think James Jnew is using multiple caps on because he jumpered 2 by mistake. Sorry I went off on a tree tangent, but the tree is a quick way to test a bunch of different values.
As far as what happened to that aluminum chass 12000. Mark sold it to pay debts.. The pic are in the VH mods thread. That's his aluminum 12000 that he started out on. It started out with Chris M trannys. Then he liked the Metro Dagnall OT better. Then he got that 78 later. Obviously he must have liked the old Iron on the 78 better. Flames1950 took those pics of his Aluminum 12000 when Mark sent it to him for repairs.. The amp is signed as well.
mightymike
Re: Real Mod 5 pics
Post by mightymike » Thu Sep 10, 2015 10:38 am
The point of all that was to say he did use a 25uf on his personal Aluminum 12000. The pics prove it, so it's a matter of fact. The stuff about the tree was to give a little insight on the dialing process many use when choosing a v2 cap, and how an off value (if it was an off value) can be arived at.
echoplexi1974
Re: Real Mod 5 pics
Post by echoplexi1974 » Thu Sep 10, 2015 11:13 am
Thanks mightymike. Great insight there. :thumbsup:
White noise, why are some of your posts disappearing? :what:
Honestly, I don't think it matters what amp he used to get those tones. It could of be any amp. He was determined to get that tone in his head no matter what! :champ:
mightymike
Re: Real Mod 5 pics
Post by mightymike » Thu Sep 10, 2015 11:38 am
No prob. :-)
Same amp as in the sticky VH Style Mod thread
Mark's first Aluminum 12000 build. Looks like he took the M err en PT out too.
Signed chassis
http://www.mediafire.com/view/vxadtj3bw ... CN0001.JPG
More gut shots
http://www.mediafire.com/view/n1zoo2414 ... CN0004.JPG
http://www.mediafire.com/view/1ulslty5l ... CN0005.JPG
white noise
Re: Real Mod 5 pics
Post by white noise » Thu Sep 10, 2015 12:39 pm
mightymike wrote:The point of all that was to say he did use a 25uf on his personal Aluminum 12000. The pics prove it, so it's a matter of fact. The stuff about the tree was to give a little insight on the dialing process many use when choosing a v2 cap, and how an off value (if it was an off value) can be arived at.
I completely agree that Mark used the Tree process!
