what is the best B+ voltage for evh sound?
- 5150loveeddie
I'll try to found an article where Ed says it relatively clear about it........let me dig my source.................BTW going at 90volts will smooh think up but you get cathode shredding unless you bring your heaters back to 6.3vac, the shredding thing is not very good if you use expensive tube like any NOS type tybe you don't won't to reduce there like......be back with that article.....Jon get in there so we can once in for all finish talking about all that supposed this, supposed that crap..................it as been cover here a few month ago anyhow!!!!
Your tone if heard on your clips are really nice already BTW....
- flemingmras
140? No that was a misprint in that article. He was really using a 240 volt variac cranked to 240 VAC!rockstah wrote: sigh... yes i have heard this way as well.. i have heard also he ran the varaic at 140volts so then who says thats the way he did it? you?
Jon
Somebody has a site somewhere where they did a whole bunch of tests and measurements regarding using a variac. The more important points were at a 110-90v drop on the variac (or 120-100) a B+ of around 490-500 drops to around 400v. The bias drops as well and the heaters are then around 5.1v. According to some old chart regarding heater voltage vs tube life anything 5v or higher wont really degrade tube life due to cathode stripping though 6.3 is best obviously. After 5v it drops pretty rapidly though. That chart was probably made using tests of old tubes keep in mind.5150loveeddie wrote:I'll try to found an article where Ed says it relatively clear about it........let me dig my source.................BTW going at 90volts will smooh think up but you get cathode shredding unless you bring your heaters back to 6.3vac, the shredding thing is not very good if you use expensive tube like any NOS type tybe you don't won't to reduce there like......be back with that article.....Jon get in there so we can once in for all finish talking about all that supposed this, supposed that crap..................it as been cover here a few month ago anyhow!!!!
- 5150loveeddie
Interesting stuff Dan, I ask that question to a few guys (Tubetramp, ******, ...) those two told me around 5.7, 5.8vac is borderline and below that you will start having life problems for the tube.......who knows really??Billy Batz wrote:Somebody has a site somewhere where they did a whole bunch of tests and measurements regarding using a variac. The more important points were at a 110-90v drop on the variac (or 120-100) a B+ of around 490-500 drops to around 400v. The bias drops as well and the heaters are then around 5.1v. According to some old chart regarding heater voltage vs tube life anything 5v or higher wont really degrade tube life due to cathode stripping though 6.3 is best obviously. After 5v it drops pretty rapidly though. That chart was probably made using tests of old tubes keep in mind.5150loveeddie wrote:I'll try to found an article where Ed says it relatively clear about it........let me dig my source.................BTW going at 90volts will smooh think up but you get cathode shredding unless you bring your heaters back to 6.3vac, the shredding thing is not very good if you use expensive tube like any NOS type tybe you don't won't to reduce there like......be back with that article.....Jon get in there so we can once in for all finish talking about all that supposed this, supposed that crap..................it as been cover here a few month ago anyhow!!!!
Its not the same as 6.3, it definitely is shorter, but the chart I saw was like a parabola. Ive seen it in quite a few places actually. It was a parabola with voltage on the x axis and life in hours on the y axis. Ill try and fin it again5150loveeddie wrote:Interesting stuff Dan, I ask that question to a few guys (Tubetramp, ******, ...) those two told me around 5.7, 5.8vac is borderline and below that you will start having life problems for the tube.......who knows really??
- 5150loveeddie
That would be great Dan!!!!!!!Billy Batz wrote:Its not the same as 6.3, it definitely is shorter, but the chart I saw was like a parabola. Ive seen it in quite a few places actually. It was a parabola with voltage on the x axis and life in hours on the y axis. Ill try and fin it again5150loveeddie wrote:Interesting stuff Dan, I ask that question to a few guys (Tubetramp, ******, ...) those two told me around 5.7, 5.8vac is borderline and below that you will start having life problems for the tube.......who knows really??
My two cents about voltage:
I have a plexi 50 reissue with metro board, sozos and oei transformer that has 475 on the plates and a 1976 stock 50 watt lead amp with original transformers with 400 on the plates. I can definitiely say that the stock 76 amp has more of the brown sound going for it. It originally came with 6550 tubes and that when you switch it over to EL34's you seem to get an automatic variac effect. I think the trannie with two plate voltages is a great idea. I'm planning on selling both of these amps to finance a 12000 series build, so email me if you know anyone who would want them. They are both killer 50 watters, but different. I often wonder what the 76 would sound like with a metro board in it. But I want to build that 67 100 circuit.
wes
wes
- sub
Billy Batz wrote: Its not the same as 6.3, it definitely is shorter, but the chart I saw was like a parabola. Ive seen it in quite a few places actually. It was a parabola with voltage on the x axis and life in hours on the y axis. Ill try and fin it again
I remember on this "graphic"
If i right remember 0.3-0.5 voltage drops halve the tube life
GibsonMarshallCelestion
- VelvetGeorge
- Site Owner
- Flames1950
The lower voltages of the mid-70's fifty watters makes them very brown indeed. My '75 does a very reasonable cop of EVH -- as close as I ever need to come. I've never thought Eddie's low end was particularly tight, so that works in the 50-watter's favor as well.texwest wrote:My two cents about voltage:
wes
- carson5150
So, are you a metal snob or what?Anonymous wrote:I say, STOP TRING TO PARODY EVH AND DO YOUR OWN THING! YOU ACT SO SILLY WITH THIS CRUD. MOVE ON AND DO YOUR PANTERA RIFFS BROTHER!
"There's no reason for a guitarist to have a big ego. You should love the Instrument more than wanting to be a rock star." -Randy Rhoads
