Winder
Post
by Winder » Sat Dec 15, 2007 9:29 am
Ruben wrote:I've done this also: clipped R28 & C11 & C12. Nice sound, but not good enough for me. I liked the EVH in script mode better and now building an Script Phase 90 (with original board & components)
I did these and thought just pulling R28 sounded best. Then I went and lost one of the caps.
beaulieu
Post
by beaulieu » Sun Dec 16, 2007 12:43 pm
i have moved my trim pot before and i donot know wher the stock setting is?
any sugestions on how i can reset it?? Its a newer orange reissue. Again i did the r28 c 11 c 12 mod!
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
gnugear
Post
by gnugear » Sun Dec 16, 2007 2:45 pm
I did a Build Your Own Clone phase 90 and love it! I built one when the first kit came out and it was a lot better than a new MXR with R28 mod. Since then I heard they updated the kit so I built another one and it's even better. I remember that the sound was different when turning the trimpot clockwise vs. counter clockwise. Can't remember which direction I decided on but I dialed out the low end flub and the effect is much more subtle, which I'm guessing is more like an original one. I used to not use it much but now I can leave it on without the effect overpowering to sound.
Gear:
'73 Super Lead
'70 Basketweave
bmf5150
Post
by bmf5150 » Sun Dec 16, 2007 3:52 pm
gnugear wrote:I did a Build Your Own Clone phase 90 and love it! I built one when the first kit came out and it was a lot better than a new MXR with R28 mod. Since then I heard they updated the kit so I built another one and it's even better. I remember that the sound was different when turning the trimpot clockwise vs. counter clockwise. Can't remember which direction I decided on but I dialed out the low end flub and the effect is much more subtle, which I'm guessing is more like an original one. I used to not use it much but now I can leave it on without the effect overpowering to sound.
i got the build your own clone phase 90 after talking to gnugear about it..i love it,way better than the reis and doesnt rob your tone plugged into the pedal.
harddriver
Post
by harddriver » Sun Dec 16, 2007 4:26 pm
I may check out a BYOC just to mess around with it and not screw up my script.
Thanks for the insights!
mgee60
Post
by mgee60 » Mon Aug 31, 2020 12:35 am
I have a phase 90 block print that had the diode replaced from incorrect polarity, The light comes on when the button is pushed but no sweeping? It sweeps only when I turn the tweaker pot. And when button is pushed there is a noticeable boost in volume. Any suggestions?
Thanks.
mgee60
Post
by mgee60 » Tue Sep 01, 2020 8:27 pm
Not sure if this posted already? I have a block print phase 90 that has replaced the diode from incorrect polarity. Now when the button is pushed, the light comes on, it gives a slight boost, & no sweep. It only sweeps with the tweaker but auto. turmimg the tweaker I get a slight sweep ?? Any ideas?
Thanks.
