Jose Master Volume question
- novosibir
A 10V zener seems to be a bit too low, 20V zener sounds to me more correct.
Larry
Larry
- rockstah
rockstah wrote:Larry, u have a part number for the zener diode i need?
im thinking this one? http://www.mouser.com/search/ProductDet ... 3-1N5357BG
- novosibir
Sorry, no!rockstah wrote:rockstah wrote:Larry, u have a part number for the zener diode i need?
I've done some experiments w/ diodes in the amp layouts in the past. Diodes from the signal path to ground, and also diodes in the cathode circuit of the tubes. But it came up, that I hate diodes in the signal path. That's simply 'not my way'!
What I write now about the use of diodes in the signal path is theory and logic, not experience.
Larry
- rockstah
so if at 20v how many watts should it be?novosibir wrote:Sorry, no!rockstah wrote:rockstah wrote:Larry, u have a part number for the zener diode i need?
Larry
how about? http://www.mouser.com/search/ProductDet ... 10-CZ5357B
- novosibir
Is ok! Even a 1W type already wouldt have been plenty!
Larry
Larry
- rockstah
ok then how about this one! http://www.mouser.com/search/ProductDet ... 78-1N4747A
- novosibir
As I've already said - plenty
Larry
Larry
- novosibir
That depends on the voltage 'above' 10V, the diode has to kill.rockstah wrote:ok. how much zener current will this diode being handling?
Again easy to determine with Ohm's law!
P / U = I; I * U = P
Have you already read some books about basic electronics?
Larry
- rockstah
- rockstah
- rockstah
