It's been a while, but I had a knee replacement, knew I needed something to do for six weeks and decided on another JTM45 build.
I had a JTM 45 reissue OT Lying around and bought the rest of the parts and went at it....pain meds and all ...LOL
But on first power up, the voltages were way off...I followed the instructions I found here, and I thought I was pretty thorough....
But on turning on the Standby I got a horrible Howell, and I switched it off immediately and began looking for errors, reflowed some solder, checked grounds, and orientation....I changed out the can caps (I had some lying around) I hooked up the output to an OX so I can hear it through headphones and not destroy my cabinets, scare cats, wife etc...But after days of debugging I get a "Motorboat" noise....can't seem to find the problem. Also, the volume controls do not work. and the bass and presence pots act like phase shifters.
While debugging I pulled the Pi tube and the noise stopped, I also pulled out the NFB resistor. No Sound....
Voltage at the plates is 475VDC
I can record the noise, or get voltages for anyone that has debugging skills....
