Hi All
I have a awesome JTM45 Metro kit/valvestorm build that sounds amazing. Most of the amp is metro kit from valvestorm. Power Trans is metro, Output trans is Classic tone, but the Choke is a Mojotone 777 "Mojo777" https://www.mojotone.com/amp-parts/Filt ... r-6L6-Amps
Any reason why someone would use this filter choke in the build? I mean, it could be many things, like maybe trying to reduce sag? Or just that is what they had? Any adverse effects from using this?
Thank You
JTM45 metro kit Mojo777 choke
Re: JTM45 metro kit Mojo777 choke
3.5H 100ohms is similar to the 3h 110 ohms used in most marshalls.
Thanks, would this make the bottom end beefier? or more farty?
Would be same as most JTM45s (that 0.5H is relatively insignificant).
Thanks for the input. It sounds amazing. Someone installed a Metro effects loop which works very well in this.
