I know this is really ridiculous, but can somebody enlighten me about the proper filtering and filtering options in a JTM45 please? I have this 1966 JTM45 sitting here for quite a while now, got a new PT from Brian Wallace and found some good old NOS tubes, but still I’m not able to fix it. I read a lot about filtering too, but to be honest, I’m still getting confused each time I’m trying to understand it properly.
Let’s start with the basics. Looking at the 1966 JTM45 schematic from Brian, there are two 16uf caps in the preamp section and two 32uf caps for the power amp section. Not too hard to understand… First I’d like to know how these caps are called. I’m going from left to right in the schematic now:
First 16uf cap – left to/after the 10k1W resistor, connected to V2b: Is this the preamp filter cap located on the board?
Second 16uf filter cap – right to/before the 10k1W resistor: ??? is this the screens/PI cap? Is this the cap located on top of the chassis? I have a single TAD 32uf cap sitting on the chassis. In George’s instructions there’s a dual cap mounted on the chassis. Why this dual cap? Because of the 16uf/32uf option?
First 32uf cap after/left to the choke, before the 10k1W resistor: How do you call that one? This ain’t no joke…
Second 32uf cap before/left to the choke, after the standby switch: ???
Both 32uf caps are part of the dual 32uf cap, mounted to the block end inside the chassis, right? But I have a dual TAD 16uf/32uf cap there…
Now I feel like 14 years old and back to school again. Aaahhh...
