The bright channel is really bright - is there a consensus of what to use on the bright channel volume pot to tame it slightly? Also, the normal channel is dead quiet (when not playing anything), but there is some hiss on the treble channel. I'm assuming that changing the cap will probably change the amount of hiss also, right? I built the kit with sozo caps and standard tranny's ,resistors and tubes. I used the extra filtering on the internal cap can.
I finally got the chance to jumper the channels, plug into a 4x12 and give it a workout and had the most fun playing I've had in a long time. My wife said it shook the house.
This is my second amp build - I've previously built a 5E3 kit, and some pedal kits. The instructions were very thorough and it went together very well. I haven't had a chance to get any pix yet. I'm planning on getting the 50 watt plexi kit next.
