Calling All Amp Techs
- LJay942
As per my thread yesterday:
http://forum.metroamp.com/viewtopic.php?f=15&t=29128" onclick="window.open(this.href);return false;
I have come to my wits end with this amp. I am now interested in sending it to someone to diagnose and fix. I simply do not have the time or patience to continue trying to fix it. I will cover all shipping expenses, parts and labor. If you are interested in this please contact me via PM or e-mail LJay942 at gmail.com (replace at with @).
Thanks again,
Thanks again,
Re: Calling All Amp Techs
You're asking a lot here. I wouldn't expect this to work out for you by New Year's Eve, especially with the shipping delays.
Static can be a real b*tch to get rid of. I assume that you tried different tubes?
One thing I do to isolate the problem is remove one 12AX7 tube at a time, starting at V1. When the problem dissapears, you've isolated to the problem somewhat. If that doesn't work, or in conjunction with this method, try grounding the signal path at incremental spots starting at the input jack. If nothing gets rid of the noise, you can move on to the power supply.
- LJay942
I think your right about the New Years Eve. I have removed that portion.jcmjmp wrote:You're asking a lot here. I wouldn't expect this to work out for you by New Year's Eve, especially with the shipping delays.
Can you explain this grounding the signal. I would being grounding the green wires using a pair of jumpers by V1, V2, and V3 correct? I'm still learning.
I ground the green wire (input grids) on V1 to V3 to see where the problem stops. If its a signal path issue, this should definitely help in narrowing down the problem.LJay942 wrote: Can you explain this grounding the signal. I would being grounding the green wires using a pair of jumpers by V1, V2, and V3 correct? I'm still learning.
- LJay942
Went through and did what you mentioned.jcmjmp wrote:I ground the green wire (input grids) on V1 to V3 to see where the problem stops. If its a signal path issue, this should definitely help in narrowing down the problem.LJay942 wrote: Can you explain this grounding the signal. I would being grounding the green wires using a pair of jumpers by V1, V2, and V3 correct? I'm still learning.
No effect on static
<edit> Removed bad advice... <edit>
my guess is a power supply problem. If you have a scope, you could check what it looks like.
Don't try grounding the grids on the power tubes, as that'll leave them with no negative bias voltage which is a very easy way of killing the tubes.
- LJay942
I only did the pre-amp section I left power amp un-touched.paulster wrote:Don't try grounding the grids on the power tubes, as that'll leave them with no negative bias voltage which is a very easy way of killing the tubes.
- Mars Hall
PM sent.
- LJay942
PM replied toMars Hall wrote:PM sent.
I think that would be the way to go, as I'm not too far from Hinsdale.
I'd try it with a different guitar, and at another location too, to make sure your house isn't part of the equation. Maybe what I've said isn't the cause, but it is simple and easy to rule out, before you want to pay someone to check it out for you.
At my local music store for example, one of the neighboring shops around it has some generator or appliance that affects certain amps very negatively, regarding noise floor. It only goes on after 5 or so, and is incredibly noticeable. It is important to not forget outside factors, since your guitar and amp are grounded correctly.
- LJay942
Thanks for all the replies!
Mars Hall recommended a local tech so I went ahead and dropped it off at his shop. We tested multiple guitars there is something going on. He said he should have it taken care of by Tuesday.
I'll let you guys know what he says.
Thanks again,
Thanks again,
Nike Snkrs
Pandora Canada Jewelry
Jordan Sneakers
Air Jordan 11
Pandora Rings
Pandora Jewelry Official Site
Jordan 5s
Pandora Bracelet
Nike Outlet Store Online Shopping
Balenciaga Triple S
Red Bottoms Louboutin
Nike Shoes
Retro Jordans
Golden Gooses Sneakers
Jordan 12 Retro
Nike Shoes Sale
Jordan Retro 11
Pandora Charms
Jordan Retro 12
Nike Shoes For Men
Soccer Cleats
Red Bottom Shoes
Retro 4 Jordans
Jordan Shoes For Men
Men Moncler Vest
Louboutin Shoes
Golden Goose Sneakers Women
Huaraches Nike
Win Like 96
Pandora Official Site
Jordan 4 Retro
Yeezy Shoes
Hermes Birkin Bag
Adidas NMD R1
Golden Goose Sneakers Sale
Nike Air Max 2018
Nike Air Force One
Air Jordan Shoes For Men
Jordan 5
Air Jordan
Nike Shoes For Women
Moncler
Air Jordan 11
Yeezy
ECCO
Jordan 11 For Sale
Nike Factory
Nike Shoes
Outlet Golden Goose
Moncler Jackets
Jordans Sneakers
Jordan 4 Retro
Air Jordan 11
Moncler Jackets
Pandora
Nike Air Max 98
New Jordans
Pandora
Jordans 11 Retro
Moncler Store
Moncler Jackets
Air Jordan Sneakers
Jordan Retro
Golden Goose
Air Jordan 12
Sneakers GGDB
Pandora
New Jordans
Fitflops Clearance Outlet
Pandora
Air Jordan
Jordan Retro 14
James Harden shoes
Balenciaga
Cheap Nike Air Max
Moncler Store
Ferragamo
Nike Mens Shoes
Nike Air Jordan
Air Jordan Sneakers
Nike Outlet
New Nikes
Nike Air Force 1
Retro Jordan
Jordan 11s
Cheap Jordans For Sale
GGDB
Pandora Charms Outlet
Air Jordans
Nike Website
Golden Goose Outlet
Pandora Ring
Nike Air Max 90 Ultra
Air Max 270
Retro Jordan
Cheap Jordan Shoes
Jordan 6
Air Max 95
Harden Shoes
Ferragamo
Jordan Retro 11
Jordan 11
GGDB Shoes
Jordans 13
Yeezys
Yeezy Shoes
Fitflop Sandals
Red Bottom Shoes
Yeezy Shoes
Jordan 9
Louboutin shoes
Jordan 1 Retro
Air Jordan Retro 6
Jordan 5 Retro
Mid Star Golden Goose
Jordan 11 Red
Kanken Backpack
Jordan 3 Retro
Golden Goose Shoes Women
Adidas Yeezy
Jordan 6 Rings
Adidas NMD
Moncler Outlet
Air Jordan 10
Jordan 12
Air Jordan 8
Pandora Jewelry
Moncler Outlet
Jordan 11s
Air Jordan 4 Retro
Nike Outlet
Valentino Shoes
Kyrie Shoes
Air Jordan 3
Jordan Sneakers
Air Jordan 11
Pandora Rings
Jordan 5s
Pandora Bracelet
Balenciaga Triple S
Nike Shoes
Retro Jordans
Jordan 12 Retro
Nike Shoes Sale
Jordan Retro 11
Pandora Charms
Jordan Retro 12
Nike Shoes For Men
Soccer Cleats
Red Bottom Shoes
Retro 4 Jordans
Men Moncler Vest
Louboutin Shoes
Huaraches Nike
Win Like 96
Jordan 4 Retro
Yeezy Shoes
Hermes Birkin Bag
Adidas NMD R1
Nike Air Max 2018
Nike Air Force One
Jordan 5
Air Jordan
Moncler
Air Jordan 11
Yeezy
ECCO
Jordan 11 For Sale
Nike Factory
Nike Shoes
Outlet Golden Goose
Moncler Jackets
Jordans Sneakers
Jordan 4 Retro
Air Jordan 11
Moncler Jackets
Pandora
Nike Air Max 98
New Jordans
Pandora
Jordans 11 Retro
Moncler Store
Moncler Jackets
Air Jordan Sneakers
Jordan Retro
Golden Goose
Air Jordan 12
Sneakers GGDB
Pandora
New Jordans
Pandora
Air Jordan
Jordan Retro 14
James Harden shoes
Balenciaga
Cheap Nike Air Max
Moncler Store
Ferragamo
Nike Mens Shoes
Nike Air Jordan
Air Jordan Sneakers
Nike Outlet
New Nikes
Nike Air Force 1
Retro Jordan
Jordan 11s
GGDB
Air Jordans
Nike Website
Golden Goose Outlet
Pandora Ring
Air Max 270
Retro Jordan
Cheap Jordan Shoes
Jordan 6
Air Max 95
Harden Shoes
Ferragamo
Jordan Retro 11
Jordan 11
GGDB Shoes
Jordans 13
Yeezys
Yeezy Shoes
Fitflop Sandals
Red Bottom Shoes
Yeezy Shoes
Jordan 9
Louboutin shoes
Jordan 1 Retro
Air Jordan Retro 6
Jordan 5 Retro
Jordan 11 Red
Kanken Backpack
Jordan 3 Retro
Adidas Yeezy
Jordan 6 Rings
Adidas NMD
Moncler Outlet
Air Jordan 10
Jordan 12
Air Jordan 8
Pandora Jewelry
Moncler Outlet
Jordan 11s
Air Jordan 4 Retro
Nike Outlet
Valentino Shoes
Kyrie Shoes
Air Jordan 3
