The standby switch squeal
- VelvetGeorge
- Site Owner
To update the problem many of you are having: the squeal or motorboating when turning the standby switch ON.
I got a set of the Valve Art KT66's back from someone who had this issue. I put them in my dead stock JTM 45 kit build here in the shop and I couldn't make them squeal.
I honestly don't think the VA KT66's are the culprit here, but they may illustrate the issue more than a typical EL34 or 6L6.
I know that several people have solved their issue by installing 5.6k grid resistors. Highlighting the fact that the noise is the product of an instability.
Something that we normally address by looking at grounding and wire routing.
Lets gather info in this thread and see if we can nail this down. On my stock kit I have Mallory 150 signal caps. Anyone using these and experiencing the squeal? Or might they be unique to Sozo?
Anyone having this issue with VA KT66's from 6 months ago or longer? Maybe a new run of these tubes is less stable.
Is your bias grounded on the pot buss?
Are your dual 32 and dual 16uf can grounded on the same lug, near the PT?
Anyone have this issue with the F&T 16uf cap on the board? The Sprague Atom 16uf?
Do your OT primary wires run parallel to the orange and green grid wires?
Thanks,
Thanks,
- VelvetGeorge
- Site Owner
- 5150loveeddie
Re: The standby switch squeal
I had that same problem just last week upgrading an jtm45 reissue, like a machine gun type motorboating, it was intermitant. I did like in your instructions adding the dual 16uf can in the chassis and reducing all the rest (filtering), tubes are Shuguang kt66 (valve art i think?) and Ei for all 3 12ax7. As soon I flipped the stby swt it started oscillating, with the 5.6k I could still have a little once in a while but no more machine gun type sqeal.......VelvetGeorge wrote:To update the problem many of you are having: the squeal or motorboating when turning the standby switch ON.
Thanks,
All caps are philips mustard, F&T cans.
Bias grounds ARE on the ground buss (pot's), yes..
Both 32u and 16u cans are grounded at the same place on the 32u gound lug
BC 22uf single is on the board
Primaries gives 9k here (******'s) I was thinking it was to much, that tranny has 8k and 6.6k also I believe, was planning to reduce it to the 8k, those wires are not so close to each other but they do cross each other once (grids and ot primaries...)(no choose here I guess)
[quote="VelvetGeorge"]To update the problem many of you are having: the squeal or motorboating when turning the standby switch ON.
Using Sozo caps on this build
Yes
Sprague
Yes with some space between them. Wires are twisted on both.
Yes
Sprague
sozo
N/A
yes
yes
F&T
yes, although mine have been moved considerably since trying to debug the problem positioning didn't make a difference.
I have VA KT66's from back in January when my kit arrived. However, I just installed the 5.6k resistors in series with pin 5 of both output tubes and the squeal is gone. No change in test voltages! No change in tone/sound!
My bias voltage had drifted a little to the low side so I re-biased, but I guess that is normal? This was the first time I biased after the initial bias back in January. All is great now.
I don't know why the 5.6k resistors worked, but it works now with no problems at all.
Thanks for all the help!
Tony
Tony
You can't hear any difference in sound, because cutoff frequency of RC filter is about 250 kHz. This RC filter is composed of 5k6 resistor and parasitic capacitance and miller capacitance of power tube and this resistor attenuate resonance circuit, composed of that 5k6 resistor, parasitic capacitances and inductances of wiring. Amp without stopper resistor is more vulnerable to this oscillations so I always put these resistors to power tubes in my amps.tfrost33 wrote:I have VA KT66's from back in January when my kit arrived. However, I just installed the 5.6k resistors in series with pin 5 of both output tubes and the squeal is gone. No change in test voltages! No change in tone/sound!
[quote="LordAli"][quote="tfrost33"]I have VA KT66's from back in January when my kit arrived. However, I just installed the 5.6k resistors in series with pin 5 of both output tubes and the squeal is gone. No change in test voltages! No change in tone/sound!
[/quote]
I built a JTM45-like kit from "Grill-man", using Mallory 150 caps, 1.5K grid-stoppers, 1K on screen -grids, and Shuguan KT66s biased at 17W/tube with Vp = 410 Vdc.
Only problem I have is that I get some snap/crackle static when the STBY Sw is opened at shut-down.........so I only flip the On/Off to OFF.
[/quote]
