'89s JTM45 without choke - why ?
Hello.
Hope you can help me. I've got a '89s JTM45 Reissue amp. I bought it used some years ago. Now I really think about to upgrade my JTM45 at first with a Metroamp JTM 45 Retrograde Kit (+Sozo Mustards) and KT66 tubes.
I looked at the circuit diagrams and I found out, that my amp does not have a choke. I only can find a special resistor under my board (WH2.5 100R Ohms 5%) that is connected to the 10K/1W resistor near bias regulator and is also connected to 50uF/500V capacitor (see attachment).
What do you think: Does it make sense to remove the resistor and to integrate a Shinrock SCH-RS20H choke from Germany (I can't get a MM choke in Germany).
Thanx a lot for your help.
Regards,
Johannes
Regards,
Johannes
- Picture of resistor under circuit board
- (728.15 KiB) Downloaded 83 times
AC/DC Angus Young sound fanatic, owner of '69 Gibson SG, Angus Signature SG, '91 Gibson SG Standard, Epiphone G-400 with '57 Classic, '89 Marshall JTM45, '92 Marshall 1987x, Marshall 1960AV Vintage 30 4x12", 16 ohms THD HotPlate
- wadeberglund
I'm not familiar with that particular RI, I'm guessing they used a resistor there instead of a choke to reduce the cost of the amp. The 100ohm resistor emulates the DC resistance of most chokes. It's cutting corners if you ask me and putting a choke in there will make it closer to an original. What you can expect if you make this change is more power supply regulation. This implies less 120Hz buzz in the output and a tighter response. It is a very cheap and easy change, so I would recommend you give it a try. If you like the loose response and a little more sag, feel free to experiment with a lower valued choke (7H or 10H).
- wadeberglund
Forget what I said about no 120Hz ripple. It does exist in a JTM45.
At first thanx a lot for your help. For me JTM45 tuning is a totally new thing. Nice that you help such a german guy like me!wadeberglund wrote:I'm not familiar with that particular RI, I'm guessing they used a resistor there instead of a choke to reduce the cost of the amp. The 100ohm resistor emulates the DC resistance of most chokes. It's cutting corners if you ask me and putting a choke in there will make it closer to an original. What you can expect if you make this change is more power supply regulation. This implies less 60Hz buzz in the output and a tighter response. It is a very cheap and easy change, so I would recommend you give it a try. If you like the loose response and a little more sag, feel free to experiment with a lower valued choke (7H or 10H).
Oh, the resistor was stock. I thought it was made after buy. Very interesting.
You talked about 7H or 10H chokes. My english is not the best (response/sag?). Is it better to use a 20H choke to get the AC/DC Angus Young Powerage album rock sound out of the JTM45 or should I use a 7H/10H choke? What are the sound differences ? Hope you can explain it for me.
Thanx a lot,
Johannes
- wadeberglund
Sure, no problem! Welcome to the forum by the way...
First, I'm not 100% sure that the resistor is stock. It looks like there are chassis holes drilled for mounting a choke and there is a hole/grommet for the leads to come through also. It may very well be that the previous owner wanted the 100 ohm resistor there instead. Chokes are a pretty cheap part, so it would be pretty weak for Marshall to not include one for cost reasons.
As for the value of the choke, let me say this: the power supply can either be described as 'hard' or 'soft'. A hard power supply is really tight, and a soft supply is loose. Sorry, those words are really subjective, but think about the difference between someone playing metal and someone playing blues. It all has to do with the feel of the amp and it is something you will be able to hear and feel in your playing once you can identify the style of power supply in an amp and how it responds when you play. The power supply on a JTM45 definitely drifts towards being a soft power supply because it has a tube rectifier and smaller filter caps. That being said, you would expect a smaller choke, but the typical value is 20H, which is high.
I would start with the stock 20H choke and see what you think. If the amp feels stiff, you may want to go lower. I'm not familiar at all with any mods Young might have done to his amps, but a stock JTM45 is an excellent start.
- 45auto
- MacGaden
- Wiki Editor
Hi Devil:
Wellcome to the Forum.
Check this: http://www.tubeampdoctor.com/product_in ... anguage=de
And this: http://www.tubetown.de
Both in German and in Germany !
MacG.
The Marshall JTM45RI that I attacked/modified was exactly the same as yours and was stock for that first series of RIs.
I used 16/16 and 32/32 filters and initially a 10H MM choke. I found it too hi-fi and too stiff with a MM OT and NOS GEC KT66s
I have since modded it again to JTM50 spec with different OT 3H choke and 32/32 and 32/32 filter cap and using Mullard xf4 EL34s - much better for me.
I suggest you get a stock Marshall 1987X choke (chassis is already drilled for it!) and lower the filter caps to 16/16 and 32/32.
I would use a Heyboer or Marstran OT.
Just my 2 Euros
Just my 2 Euros
Hi. Thanx for your answer.neikeel wrote:The Marshall JTM45RI that I attacked/modified was exactly the same as yours and was stock for that first series of RIs.
Just my 2 Euros
Are you also an AC/DC sound fanatic ?
I already have got a 1987x and I like that sound. It's more a AC/DC Live sound. But to get the studio "blues" sound of Angus which you can hear e.g. on the Powerage album I want to "tune" my JTM45. Does your JTM45 (JTM50 rebuilt) sound like that studio sound ?
At first I don't want to change the OT (output transformer), but the cheap choke. Do you really think a standard 1987x choke is better than a custom vintage 20H/10H/7H choke for the JTM45 to get the studio sound ? Where are the differences in sound ?
Thanx you very much !!!
Regards,
Johannes
- monsterwalley
I love Angus Youngs tone generally but confess I cannot comment on the differences in tone on all the albums except for I prefer his studio sound (although Donington DVD is pretty good).TheRedDevil wrote:Hi. Thanx for your answer.neikeel wrote:The Marshall JTM45RI that I attacked/modified was exactly the same as yours and was stock for that first series of RIs.
Just my 2 Euros
Regards,
Johannes
I think that the JTM50 (as per layout on the 50watter forum) is the nearest (using EL34s) although I have seen somewhere - probably here
For me the Marshall choke was cheap, off the shelf, fitted without hassle and does the job - when it comes to the OT I am much more picky
- mightymike
I'm tuning a 50 watter sent to me by another forum member, who has a tonal goal of the first couple bars of Shoot To Thrill.
The amp has a JMP50 board on the JTM chassis. (power section)
I fixed the bias circuit
And Heyboaer sent the guy an 18 watt PT instead of the JTM 45 PT.
So he only had 295 on his PT secondaries, and 378 on the plates, if I use the Diode Plugin, (even less if I use a Tube Rectifier)
So a replacement PT is on the way.
Every Voltage chart for a JTM 45 in my MArshall book shows 330 on the scondaries, but varys between 430 to 440 on the plates (with tube rectification)
I'm sure with a diode rectifier that would be even more, so we went with the standar 330 secondaries. But I see where guys like Brian Wallace use the 350 secondaries, which would put you at 450 with tube rectifiers.
I've also been trying some different boost caps. I see the that they used .68uf on the 1987, but I also tried a 330uf (like a 12000). I also uped the filter cap next to the rectifier, to a 32+32 (it had a 16+16) The increased filtering helped with the buzz, but made it sound thicker and tighter bottom, but less open.
There's some buzzyness isues, so I upped the fizz to a 100pf.
Which helped.
I think once the right plate voltages are acheived, that the buzzyness will be much improved, and mayve with the higher plate voltage that increased filtering will sound better.
I've also heard of choke being replaced by resistor with ACDC, and will look into that as well.
Which helped.
- 45auto
that's the link i posted above. wasn't there discussion of the no-choke acdc mod?
- mightymike
OK now I remember.
Yeah That sounds like a fun experiment worth trying.
I like Larry's design so you can find where is the sweet spot, but I also would like it to be bypassable to the choke.
SO all you'd need a 1k/50w reostat, and the 20uf after the choke in line with the screens, and a nice heavy duty switch.
Re: '89s JTM45 without choke - why ?
Air Max 2019
Jordans Sneakers
Nike Clearance Outlet
Nike Air Presto
Adidas Ultra Boost
Adidas Yeezy
Christian Louboutin Shoes
Adidas Yeezy
Nike Clearance
Pandora Jewelry
Jordan 11 Gamma Blue
Nike Metcon
Nike Air Force Ones
Nike Air Max 720
Air Force 1
Adidas Yeezy
Christian Louboutin
Nike Shoes For Women
NMD
Lebron 16 Shoes
Pandora Bracelet
Air Jordan Shoes
Vans
Valentino Sneakers
Nike Basketball Shoes
Nike Factory Outlet
Nike Store
Pandora Bracelets Clearance
Christian Louboutin shoes
Nike Outlet
Jordan Kids
Nike Running Shoes
Pandora Sale
Air Max 95
Nike Outlet Store
Nike Shoes
Louboutin Shoes
Red Bottom Shoes
Adidas NMD
Red Bottom Shoes
Christian Louboutin Shoes Sale Outlet
New Nike Shoes 2019
Christian Louboutin Outlet
Nike Air Max 98
Louboutin Heels
Fjallraven Kanken
Pandora Charms
Ferragamo Belt
Air Force 1
Yeezy Shoes
Pandora Charms Sale Clearance
Nike Clearance
Jordan 11
Nike Factory Store
Louboutin Shoes
Fjallraven Kanken Backpack
Pandora Jewelry
Yeezys
Lebron James Shoes
Pandora Jewelry Official Site
Nike Lebron 17 Low
Nike Outlet
Jordan Retro 13
Huarache Sandals
Nike Outlet Store
Nike Store
Nike Epic React
Pandora
Nike Outlet Store
Kyrie Shoes
Adidas Sneakers
Air Max 98
Nike Shoes
Pandora Bracelets For Women
KD Shoes
Christian Louboutin
Pandora Earrings
Yeezy Boost 350 V2
Adidas Ultra Boost
Nike Cortez
Pandora UK
Pandora
Nike Air Max 270 Men
Nike Outlet
Yeezy Boost 350
Pandora
Nike Factory Outlet
Nike Factory Store
Adidas Stan Smith
Golden Goose
Nike Zoom
Nike Air Force One
Nike Shoes
Cheap Nike
Air Jordan Sneakers
Moncler Outlet
Nike Sneakers For Men
Nike Running Shoes
Nike 720 Air Max
Nike Cortez
Pandora Ring
New Nike Shoes
Nike Outlet
Nike Running Shoes For Men
Pandora Necklace
Mens Nike Shoes
Nike Air Max
Nike Air Zoom Pegasus
Louboutin Shoes
Nike Sneakers
Nike Air Max 95
Asics Shoes
Nike Free Run
Yeezy 500 Black
Salvatore Ferragamo Shoes
Michael Jordan Shoes
Nike Outlet
Nike Shoes
Air Jordans
Red Bottom Heels
Nike Shoes
Nike Cyber Monday 2020
Nike Sneakers
Lebron Shoes
Nike Clearance
Lebron 16
Yeezy 550
Ferragamo
Jordan Retro
Pandora Jewelry
Yeezy
Nike Kyrie
Nike Factory
Jordans Sneakers
Nike Air Presto
Adidas Ultra Boost
Adidas Yeezy
Adidas Yeezy
Nike Clearance
Pandora Jewelry
Nike Metcon
Nike Air Force Ones
Nike Air Max 720
Air Force 1
Adidas Yeezy
Christian Louboutin
NMD
Lebron 16 Shoes
Pandora Bracelet
Air Jordan Shoes
Vans
Valentino Sneakers
Nike Factory Outlet
Nike Store
Nike Outlet
Jordan Kids
Nike Running Shoes
Pandora Sale
Air Max 95
Nike Outlet Store
Nike Shoes
Louboutin Shoes
Red Bottom Shoes
Adidas NMD
Red Bottom Shoes
New Nike Shoes 2019
Nike Air Max 98
Louboutin Heels
Fjallraven Kanken
Pandora Charms
Ferragamo Belt
Air Force 1
Yeezy Shoes
Nike Clearance
Jordan 11
Nike Factory Store
Louboutin Shoes
Pandora Jewelry
Yeezys
Lebron James Shoes
Nike Lebron 17 Low
Nike Outlet
Jordan Retro 13
Huarache Sandals
Nike Outlet Store
Nike Store
Nike Epic React
Pandora
Nike Outlet Store
Kyrie Shoes
Adidas Sneakers
Air Max 98
Nike Shoes
KD Shoes
Christian Louboutin
Pandora Earrings
Yeezy Boost 350 V2
Adidas Ultra Boost
Nike Cortez
Pandora UK
Pandora
Nike Outlet
Yeezy Boost 350
Pandora
Nike Factory Outlet
Nike Factory Store
Adidas Stan Smith
Golden Goose
Nike Zoom
Nike Air Force One
Nike Shoes
Cheap Nike
Air Jordan Sneakers
Moncler Outlet
Nike Running Shoes
Nike 720 Air Max
Nike Cortez
Pandora Ring
New Nike Shoes
Nike Outlet
Pandora Necklace
Mens Nike Shoes
Nike Air Max
Louboutin Shoes
Nike Sneakers
Nike Air Max 95
Asics Shoes
Nike Free Run
Yeezy 500 Black
Nike Outlet
Nike Shoes
Air Jordans
Red Bottom Heels
Nike Shoes
Nike Sneakers
Lebron Shoes
Nike Clearance
Lebron 16
Yeezy 550
Ferragamo
Jordan Retro
Pandora Jewelry
Yeezy
Nike Kyrie
Nike Factory
