Will this hurt my Speakers
I put 2 V-30s into a twin-12 silvertone Cab. It is 8in deep.Is it Too small I also made it a closed back cab.I use it to run my 1959 on 3-5 vol.just to practice,is it too small?
Re: Will this hurt my Speakers
I doubt it. I would need to know more to say for sure. I doubt anybody would damage a pair of speakers practicing unless they were wired wrong or something.
- Mars Hall
Even though it's called the "Vintage 30" they are rated for 60 watts. Here's the spec sheet. You should be fine.
http://professional.celestion.com/guita ... c.asp?ID=4" onclick="window.open(this.href);return false;
I think there alittle too bright sounding.If I was to put a 25 watter in and take a V-30 out would I still be OK.
- bluesbreaking
Almost certainly not. If you're running your amp above 1 or 2 with 2 speakers and one of them is rated at 25, then you're basically assured a blown 25-watter. That's because your cabinet is only rated as high as the number of speakers * the rating of your least-rated speaker. Even if you have 1 60-watter in there, your cab will still be rated 50 watts because of the 25 watter. Scumback sells 65-watt and 100-watt versions of the 25-watters (and 30-watters if that's more the sound you're after).bob barcus wrote:I think there alittle too bright sounding.If I was to put a 25 watter in and take a V-30 out would I still be OK.
thanks I didn't know that
