My 4x12 Project Photo's!
db_inst_amp
Re: My 4x12 Project Photo's!
Post by db_inst_amp » Thu Feb 11, 2010 9:20 pm
My thoughts on jointery has always been that gluing surface area wins. This is why lap or rabbit joints are not considered the best choice for joining speaker cab sides. By fact of geometry the box joint will have a bunch of surface area to glue. The angle on the dovetail prevents the tight pin spacing that can happen with a box joint. This is what I think comes through in the link and perhaps why they are used so often. Also note, those are blind dovetail joints in the test, not full depth pins like the ones here. Not really an apples to apples test. Would have been better if it were equal glue surface area.
The dovetail adds the touch of craftsmenship and are much more attractive. As far as sound, I never rule out anything affecting it.
Here is some test data of dovetail angle with a very interesting result for glued and dry. http://www.akeda.com/documents/DovetailAngle.pdf
Enjoy!!
Have a good one,
Derrick
Only 2 goats were sacrificed in the making of this cabinet.
hpshooter
Post by hpshooter » Sun Jan 23, 2011 2:23 pm
I know this post is old, but can anyone give the plans or any information on this build? I would like to see pictures of the final project. And was wondering if Marshall corners were used? I want to use original corners, but not sure of how to due this.
audioclone
Post by audioclone » Sun Jan 23, 2011 2:40 pm
hpshooter wrote:I know this post is old, but can anyone give the plans or any information on this build? I would like to see pictures of the final project. And was wondering if Marshall corners were used? I want to use original corners, but not sure of how to due this.
Is that what you're looking for?
810d1184091825-1960a-slant-cab_rev1.pdf
(77.3 KiB) Downloaded 450 times
hpshooter
Post by hpshooter » Sun Jan 23, 2011 2:51 pm
Well this plus actual pictures and directions... LOL
