Need held identifying age of 1960a cab
RagnarMarGunn
Post by RagnarMarGunn » Fri Dec 14, 2012 3:03 pm
Gents,
Justed scored this 1960a here in Iceland, can anyone informe me on the age of the cab and the speakers?
http://s624.beta.photobucket.com/user/R ... 3.jpg.html
http://s624.beta.photobucket.com/user/R ... 9.jpg.html
http://s624.beta.photobucket.com/user/R ... b.jpg.html
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
Re: Need held identifying age of 1960a cab
Post by neikeel » Fri Dec 14, 2012 4:23 pm
Looks like a 4x10 to me?
demonufo
Post by demonufo » Sat Dec 15, 2012 5:06 am
Yup definitely 10's, and not a 1960 cab...
So I like purple, okay!!!!!!
jape88
Post by jape88 » Sat Dec 15, 2012 6:12 am
That's an unusual cab?
As far as I know marshall didn't do the 4x12 square shaped cab for 10's until the mid 80's but there is a record of a cab model 2038 with a build date of one year :shock: (1972), could be slightly smaller though? ...BUT yours has metal handles (finished late 71) basketweave cloth (finished mid '71) and the celestions speakers are dated Jan '70? so I'm thinking this could be either a special order or an altered 12" with a newer baffle added (need closer pics), the horizontal baffle strip is out of line which is a bit odd for production.
Your speakers are not the more common one's and I've never found any history on them but should have pulsonic cones ending in 002 plus I think they could be 10 watters so take care with the volume!
bill bokey
Post by bill bokey » Sat Dec 15, 2012 6:51 am
Jan '71 I think.
RagnarMarGunn
Post by RagnarMarGunn » Sat Dec 15, 2012 10:03 am
It's definitely a 2038 cab like this one:
http://www.amparchives.com/album/Marsha ... index.html
Are these speakers any worth?
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
BaronGreenback
Post by BaronGreenback » Sat Dec 15, 2012 10:42 am
Jan 71, 4x10, pretty rare. shame about the stained grill.
Scumback Speakers
Supporting Advertiser
Post by Scumback Speakers » Sat Dec 15, 2012 10:47 am
Ragnar, your pic links aren't working for me, but if it's like the 2038 on the bottom, the speakers appear to be 9834 10" Greenback speakers. If they're original they use the Pulsonic 102 002 10" cone, and they are good for 10-12w MAX, so that cab should be rated at 50w Maximum, meaning you'd need two of these to crank a 50w Plexi into safely.
9384 10" cone pic: http://www.scumbackspeakers.com/greenbacks/9384cone.jpg" onclick="window.open(this.href);return false;
9384 10" frame pic: http://www.scumbackspeakers.com/greenba ... 4frame.jpg" onclick="window.open(this.href);return false;
RagnarMarGunn
Post by RagnarMarGunn » Sat Dec 15, 2012 11:09 am
Jim, I´ll send you these pics in email :-)
Yes, they are 9384, I did a swap, Marshall 1966a 2X12 cab for this one and also received $150, good deal?
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
jape88
Post by jape88 » Sat Dec 15, 2012 1:00 pm
Ragnar, if you need to make up another cab to run with your amp as Jim says, I've got five 10" spks that I have no use for and taking up space!...
9384 matched pair DC8X (April '70, hence my dating mistake above :lol: ) pulsonic cone 461124002
7442 matched three KK21 (Oct.77) 8401 cone codes. :lol:
:D
FrankieFeenixx
Post by FrankieFeenixx » Mon Dec 17, 2012 5:12 pm
I have a '72 2038 cab with original 9384 speakers also. It's a beater though - replaced grill and some other issues. I've cranked my 50 Watters thru it plenty of times and have not had any problems. Marshall rated these cabs at 60W. These are great cabs for when you need to tame your volume. The 10's are somewhat inefficient when compared to G12's. They seem to get to a certain volume level and then level off, no matter how much higher you push your volume knob. I've even played my Laney 60W amp thru it a few times, and that is a powerful amp (though I wouldn't recommend it on a regular basis).
:rockon:
FrankieFeenixx
Post by FrankieFeenixx » Mon Dec 17, 2012 5:17 pm
RagnarMarGunn wrote: I did a swap, Marshall 1966a 2X12 cab for this one and also received $150, good deal?
I assume that was an '80s model 1966A, probably with 75W speakers? If so, you got a KILLER deal, you nearly stole that cab. I'd put a value of at least $800 on that 2038 cab.
RagnarMarGunn
Post by RagnarMarGunn » Wed Dec 19, 2012 4:40 pm
Yes I know, it's a steal :-)
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
