Post
by shakti » Sat Mar 04, 2006 3:39 pm
Did you use both, or just one?
This is the older version of the LB, right? Looks like that in the photos. I have an 8 ohm and a 16 ohm, great boxes. I think I prefer them over the Hotplates by a hair, at least for moderate attenuation.
Anyway, I think the 120W rating is only peak rating, and not continuous. A 100-watter at full tilt will put out 150W peaks if not more. The LB is not built to take a 100-watter. I use mine with 50-watters.
Are the boxes still working? I thought I toasted mine with a Super Bass a while back when I saw smoke coming out and smelt the bad smell of a burnt resistor. Turns out I only toasted a resistor in the headphone circuitry, so that's the only part not working now. At the time I was running it straight through though, no attenutation. Did this happen while you attenuated the amp? I can't remember exactly, but I *think* the resistor I toasted was in the same place as yours.
Anyway, if you want to find out, I got good help from a guy called Edwin Kool (I think) at Koch. Try to email them, might take a while to hear back, but they were very helpful to me and emailed me a schematic (which I lost in a computer crash...why I moved to Mac...but I'm rambling)
