I've found this very interesting thread on an Australian Forum.
http://www.guitargear.net.au/discussion ... 91.45.html" onclick="window.open(this.href);return false;
I've subscribed to the forum to ask some questions but the admin didn't enable my account yet
So I'll ask here.
They guy basically cloned the UA and made a way better build.
He's also wound his own inductor. It's a 2.1 mH aircore coil and it shouldn't buzz like the UA usually does.
It seemed very simple to me so I looked for a 300w 2.2mH aircore inductor and I've found one used for hi-fi crossovers. Made in UK.
I wired it in and I tried with a 30w amp. As soon as I flicked the 'plexi switch' the amp blew the HT fuse
I've put a new fuse in. Same result, the amp sounds very fizzy as if there was no load and then the fuse blows again.
I've wired the old inductor back in and everything works again?
Do you have any idea? The UA inductor is a ferrite core inductor. the wire is thin, maybe gauge 20? or 22?
I tried to pot it with some nail polish but the buzz reduction was minimal.
The other inductor is 4 times bigger and the wire gauge is much larger too... does this matter to the load? It's still wired in series with the resistors anyway...
