I NEED AN ATTENUATOR
clukeglue
Post by clukeglue » Wed Jul 04, 2012 2:54 pm
Hey guys,
like many of you, I'm looking for the best most transparent attenuator i can get for my plexi. The only one that seems perfect to me is the Aracom. I hear only rave reviews and it has a bunch of nice features. One in particular is you can have a head with different impedance than your cab. This thing costs like 700 bucks. I can't afford that and i cannot find any used. So i need the next best thing. What do you all recommend. It seems like the THD hotplate is a favorite of many people, the only thing i really dislike is you have to buy the one for your amp's impedance. You cannot change that like on most attenuators. SO please recommend me a few attenuators that are good and under $700! Ill be using it either for my JTM 45 or my super bass.
thanks!
Janglin_Jack
Re: I NEED AN ATTENUATOR
Post by Janglin_Jack » Wed Jul 04, 2012 3:44 pm
I thought the Dr Z Airbrake was great.
Mike
Ferrari-Dude
Post by Ferrari-Dude » Wed Jul 04, 2012 10:50 pm
I have used a few THD HotPlates over the years and they are basically very good. They are still the choice for my rig.
The box does alter your tone a bit when set for heavy attenuation. I think this is unavoidable with most attenuators, unless you are lucky enough to find a Faustine, which are not made anymore and are not in the price range of most mortals.
I've also used a Scholz PowerSoak, which I rather liked the sound of. They sound great with an older NMV Marshall in dimed position.
Have you ever considered an isolation cabinet, like the Randall, as an alternative? They work pretty well for recording and band use.
-Dono
1972 Marshall Super Bass
"Can you hear me now?"
guitar007
Post by guitar007 » Wed Jul 04, 2012 11:41 pm
Check out the Rock Crusher.
~guitar007
6burgh
Post by 6burgh » Thu Jul 05, 2012 8:42 am
Aracom. Indistinguishable tone down to mouse fart levels. Worth every penny and easily as valuable as another amp if it allows you to play your amp in small spaces/venues. Plus the Aracom guys are great to deal with as is Cliff from DAG.
clukeglue
Post by clukeglue » Sat Jul 07, 2012 11:35 am
thanks guys. can't go with aracom as i said before.....i don't have 800 bucks to spend on an attenuator
planetjimi
Post by planetjimi » Sat Jul 07, 2012 12:16 pm
find a used power brake on ebay last time I checked you could get one for about $200
shakti
Post by shakti » Sat Jul 07, 2012 3:24 pm
Alex' Attenuator is what you're looking for. It's about half the price of the Aracom, and by all accounts as good/better/in the same ballpark as the Aracom or Faustine. I have three of them (two hundred watt ones and one earlier with less wattage rating) and if I am going to buy another attenuator it will be another Alex.
You have to select an impedance to match your amp, but as long as you attenuate about 6 dB or more, you can use it with just about any cab impedance.
Tone seaker
Post by Tone seaker » Sat Jul 07, 2012 7:22 pm
I use the UA and like it. It sounds really good, better sounding than the hot plate or power brake. I like the smooth dial volume lets me get the exat level i need and dual footswtichable volumes for live gigs where i need to put it up a little for leads. It works good with mutltiple amp set ups. I use it with my fender combo or my marshall or any tube amp.
slashl33t
Post by slashl33t » Sun Jul 15, 2012 3:51 pm
Id stay away from the UA if your going for something transparent. I sold mine after a week due to how differnt it would make the amp sound. The alex priced at 400 or so from what i heard is the best attenuator out right now. Still saving up myself to get one :cry:
*Rig*
*Epiphone Les Paul Custom Alpine
#535q Wah
*Marshall 2203 SIR #34/#36 Switchable
stratonenator
Post by stratonenator » Sun Jul 15, 2012 5:49 pm
If you are looking for the most cost effective option, I recommend nabbing a powerbrake for cheap on the bay and with a little soldering you can take out all the tone shaping-Fan- etc. and install some big power resistors instead. Makes it a really tasty and usable tool.
So you think your Mesa-Boogie is cool? You won't even be able to hear it over my Marshall Superlead
Tone seaker
Post by Tone seaker » Mon Jul 16, 2012 11:28 am
slashl33t wrote:Id stay away from the UA if your going for something transparent. I sold mine after a week due to how differnt it would make the amp sound. The alex priced at 400 or so from what i heard is the best attenuator out right now. Still saving up myself to get one :cry:
The alex is not leagaly rated to tour to europe. so if your staying here its really good. My UA is almost totaly transparent. Way above the power brake and hot plate
clukeglue
Post by clukeglue » Mon Jul 16, 2012 2:46 pm
hey guys thanks for all the help. i found out that the rock crusher can handle a 100 watt aimed plexi so i went with that. i haven't heard any negative reviews and you can switch from 8 to 16 ohms.
thanks y'all!
guitar007
Post by guitar007 » Mon Jul 16, 2012 5:18 pm
clukeglue wrote:hey guys thanks for all the help. i found out that the rock crusher can handle a 100 watt aimed plexi so i went with that. i haven't heard any negative reviews and you can switch from 8 to 16 ohms.
thanks y'all!
8)
~guitar007
Tone seaker
Post by Tone seaker » Tue Jul 17, 2012 11:24 am
I have heard they are really good. how does it sound transparency wise :)
