How to test audio cables?
Posted: Wed Jan 18, 2012 10:27 am
by FL6
Is it just a simple ohms resistence test with your multimeter or is there a more reliable way?
Re: How to test audio cables?
Posted: Fri Jan 20, 2012 10:07 pm
by clinchfx
Yes, you can test a cable with a multimeter.
For a guitar cable, you have to test three ways:
Tip of one end to tip of the other end. This should read very low Ohms. Remember that even your meter leads can have a few ohms resistance, so you probably will not get zero Ohms. If your meter has a continuity test function, it should beep.
Do the same test between the sleeve of one end and the sleeve of the other end.
If both measure OK, test between the tip and sleeve at one end. This should read open circuit or no beep.
Using a meter is fiddly. If you need to test a lot of different cables, there are a number of test boxes available that can test guitar, XLR, RCA and other cables. There are some at
http://www.seismicaudiospeakers.com/Cab ... -s/380.htm If you are into DIY, there are schematics around the internet for making your own.
You just plug the cable into the appropriate sockets in the box and select the appropriate function.
Peter.
Posted: Mon Feb 13, 2012 4:34 pm
by FL6
Thanks I will test that out.
Posted: Fri Feb 17, 2012 10:09 am
by 54strat
After checking with a meter; plug one end into a guitar, the other end into an amp, turn everything on and up, then shake the cord around a little. Any change in sound/noise? Do you hear any microphonic like noise? Yes-replace it. No-you're good.
Posted: Thu Feb 23, 2012 11:46 pm
by FL6
54strat wrote:After checking with a meter; plug one end into a guitar, the other end into an amp, turn everything on and up, then shake the cord around a little. Any change in sound/noise? Do you hear any microphonic like noise? Yes-replace it. No-you're good.
This worked the best. I wiggled one cable and it was loud and when I took the end apart the copper was completely severed. I looked at the other end and only a few strands were hanging on.
Posted: Fri Feb 24, 2012 2:24 pm
by 54strat
I'll have to admit to being a bit of smart aleck on that response
I am just not a believer in paying huge money for high end cables, or worrying about them much in general. I'm fine with Horizon's for about a dollar a foot. Use them until they go south, go get some new ones. I just replaced a pair I'd been using for over fifteen years because they were getting noisy...the outer pvc will dry out and crack over time, and being stomped on with boots doesn't help either.
Even the cheapest cords available now are better than what Hendrix used
Posted: Fri Feb 24, 2012 5:10 pm
by FL6
54strat wrote:I'll have to admit to being a bit of smart aleck on that response
But what can wear them out...weather?
Posted: Sat Feb 25, 2012 11:33 am
by 54strat
The answer to this is in the previous post. I used my last pair of cords for 15 years. Over time the outer rubber/PVC will deteriorate/dry out and cracks will appear. Stepping on them with hard shoes can break up the braided shield and this is when a cord will start getting noisy, make crackling sounds when you move around on stage.
