Variac question
Capt Vemo
Variac question
Post by Capt Vemo » Wed Oct 12, 2011 4:29 pm
I have whats probably gonna sound like a dumb question to most of you. So get your jabs in LOL but I was curious if I have one of the Lar/Mar MVs installed in my plexi replica. Im running the volume on the front of the amp on 10 and the MV around 3 for a nice comfotable bedroom volume. If I was to use a variac turned down to 90 volts like EVH did would it still give me more gain at that volume setting? Or would I need to really crank it to get abit more sustain and gain out of it?
A wise man once said:
"There is no right piece of gear, only the next piece of gear."
He eventually went broke, but his tone was incredible
YMI5150?
Re: Variac question
Post by YMI5150? » Wed Oct 12, 2011 5:28 pm
gain is similar, less harsh, but volume drops a bit.
be careful if you're using George's PT. from my experience, the heater voltage drops below 2.7VAC once I get below 100 VAC input on the variac. I've been instructed to stay above 2.7 so have not explored variac settings below 100 VAC.
Capt Vemo
Re: Variac question
Post by Capt Vemo » Thu Oct 20, 2011 11:13 am
Ive been steared away from dropping the volage on one down to say 90volts like EVH did. But I have another question about using them. I honestly think my voltage in some of the outlets in my house vary abit. And is actually going up and down while Im playing. Would this be something I could use to keep the voltage at a steady 110 voltage for my amp ?
Re: Variac question
Post by Tone Slinger » Thu Oct 20, 2011 3:03 pm
Yes
AustinTx
Re: Variac question
Post by AustinTx » Thu Oct 20, 2011 7:20 pm
No....you need a voltage regulator to keep you AC steady.
Variac will just give you a percentage of the wall voltage,
if the wall voltage varies...the output of the variac will vary also
Dropping voltage with a variac will drop the volume a bit but..
2.95v is as low as you wanna go on a heater, according to the gurus...
Austin Texas
http://www.doug-morrison.com" onclick="window.open(this.href);return false;
908ssp
Re: Variac question
Post by 908ssp » Fri Oct 21, 2011 8:55 am
According to experts I respect heater voltage issues are way over stated. Nobody has ever posted loss of a tube due to too low heater voltage. And the spec everybody quotes is developed for extreme high power broadcast tubes not tubes is guitar amps. I personally don't go lower than 100 volts as I think the quality of the tone changes in a way I don't care for. I am not worried about wearing out a tube in any case.
AustinTx
Re: Variac question
Post by AustinTx » Sat Oct 22, 2011 3:07 pm
908ssp wrote:According to experts I respect heater voltage issues are way over stated. Nobody has ever posted loss of a tube due to too low heater voltage. And the spec everybody quotes is developed for extreme high power broadcast tubes not tubes is guitar amps. I personally don't go lower than 100 volts as I think the quality of the tone changes in a way I don't care for. I am not worried about wearing out a tube in any case.
True True...in my post I said "according to the gurus"
I have been running with low heater voltage since 85..without any problems
Austin Texas
