So I decided, since I had all three types lying around (I use the Brass and the Titanium as different flavors for different applications now, and have the originals as paperweights), I have Pro Tools and am only moderately afraid to use it
First order of business was to reinstall the original (eww) standard 37mm block for the "reference riff/MP3". After slapping back on the standard, I recorded two sample riffs, one slightly dirty and one balls out to get a feel for their individual characteristics in regards to open chords, palm muting, and overall dynamics. For this test I used PODfarm(I know, almost blasphemy to mention here, but I only had a day to do the test...lol) and Recabinet - a Marshall Plexi and Soldano emulation both running into the same Recabinet "Green 4x12" with a single 121 mic emulation. I'd then repeat the process with the other two block types- same emulations, same settings, same guitar - different block each time.
Here's the riff(s) with the Standard block:
SoundClick artist: Jay's Gearwhore - page with MP3 music downloads
Once that was done, I also took the opportunity to install the FloydUpgrades Brass Spring Claw and Noiseless spring set for the two "upgraded" riff examples, as I wanted to illustrate the full tone-freak Floyd Rose overhaul process.
Those were quickly swapped out, then it was on to the Brass Block. Here's how that one went:
You can tell in that clip the low end is now seemingly boosted, and the tone is fatter overall. Gone is the dreaded Floyd Rose "thinness" players long complained of, and note transfer seems to have improved as well. The mids seem thicker and the highs seem to have been warmed up as well, without becoming screechy. There's also a noticeable increase in sustain. Definite UPgrade.
Brass alone is impressive, (and one could certainly live with it) but - if you really want to go tonal crackhead with it, Titanium IS the push over the cliff. It is more like Brass' evil cousin. Everything Brass does, it seems to do "one louder". The sustain increase is most dramatic, making notes seem to jump off the fretboard...there's something more... aggressive about the highs too, but it's not at all harsh...check it out:
So now at least no one has to ask me to tell them what the different advantages of the blocks are now...you can hear them for yourselves...
