Bias question
- sweetwilliam
Bias question
What two points do I measure at to get the bias reading?
Will
Conficius says-"Good Marshall makes angry neighbors!"
- rockstah
Re: Bias question
the way i do my bias:sweetwilliam wrote:What two points do I measure at to get the bias reading?
meter on 2dcv setting
black to chassis
with 1ohm resistors installed on power tubes( pins 8 and 1 are tied together and resistor goes from pin 1 to ground), red to tube side of the resistor.
hope this helps
Mark
- sweetwilliam
- rockstah
- sweetwilliam
- sweetwilliam
- sweetwilliam
- rockstah
time to get some 1ohm resistors on the tubes or get one of these i guess - http://www.amp-head.com/product_info.ph ... ucts_id=30
- sweetwilliam
- sweetwilliam
- sweetwilliam
- novosibir
Right! On 6V6's and 6L6's pin1 (beam forming plates) is internally connected to pin 8sweetwilliam wrote:Nothing happening on pin 1, at least on JJ 6V6's. I've got an old pair of Emerson brand that have a pin 1, but these JJ's don't. Guess I could just go from pin 8 to ground.
Larry
