Annoying String Buzz
- dirtydeeds22
So, I've raised the strings, gave some relief to the neck, and still have the freakin' string buzz.
Anybody have a good method of locating the offending fret and treating the problem short of dressing all the frets?
Jeff
Jeff
I WANNA BE ANARCHY
String Buzz
If it's a Strat I won't worry if only one string Is it a strat? If you havr a 2foot steel rule lay on frets check under each fret with a feeler gauge or use a 6in and see if each fret drops down from the next .Plan B.take it to a good repair shop.
- Country Boy Shane
- dirtydeeds22
It's on the Low E and A strings roughly in the 3rd to 7th fret area, from what I can pinpoint. It's on my les paul.
Yeah it adds to the tone all right, but not in a good way. Strum a chord --- BRAAAANGzzzzzzz---- at the end of the chord. Yuck.
I looked into some tools thru Stewmac.com, but those fret tools are EXPENSIVE.
It's really frustrating, I can handle a little buzz, but this is too much. Just sounds shitty.
I'll have to try the metal straight edge technique, but I'm afraid it might require some fret work, and no repair shops within a 3 hr distance. So it's up to me.
Jeff
Jeff
I WANNA BE ANARCHY
If you end up deciding to do this yourself, make sure you do some studying on the subject before you take a file to your frets. It is very easy to lunch a fret if you do not kow what you are doing. Stewmac sells videos on fretting, or check out www.projectguitar.com and mcs.acidpit.org in the Brotherhood of Wood forum for more info and answers to any questions you might have.
Apparently once you start working on your fret, you should be able to feel through the file when the fret is done. I have no clue on what they mean by that as I do not mess with any fretwork on any of my guitars.
- dirtydeeds22
- daniel
Gibson necks are far from perfect too. After my band got in the accident last year I took my les paul to Michael Tuttle(www.bestfrets.com). Before he got a hold of it I had all kinds of buzzes you couldn't get out with a basic setup. He refretted the guitar w/stainless steel frets, put in a bone nut, and perfected the neck shape. My buzz issues are gone and I can't believe how well the guitar plays. The stainless steel frets are cool too, they don't wear down near as fast as traditional fret wire. The only downside is that they chew up your strings a little more.
ROCK N BLOODY ROLL
Don't start hack'n LP for Buzz
Hi again Make the drive,Do NOT start messing with your LP This is most likly a easy fix $35-$50 A LP is not something you want to try working on,when you have NO idea what you are doing,If you want to learn buy a cheap Strat copy and slowly build up some tools and books.This is the Best way to go Good luck,Don't Fuck, your LP
String Buzz
If you try to sand it out with a long block,You still havr got to recrown the frets.And you don't have the tools or the skill Are you sure there is not a small repair shop in SSprings,they may know a local pro.With all the rich Ski people who come up there I am sure some one in town may be of help or drive in to Denver
- dirtydeeds22
- Country Boy Shane
