Grounding Question
sweetwilliam
Grounding Question
Post by sweetwilliam » Sun Jan 22, 2006 4:26 pm
Where is the best place to ground the cathodes of power tubes?
Will
Conficius says-"Good Marshall makes angry neighbors!"
Post by Flames1950 » Sun Jan 22, 2006 5:32 pm
Most people use a grounding lug right on each socket's mounting bolt or rivet. Are you looking for a different way to do it? Noise problems?
novosibir
Re: Grounding Question
Post by novosibir » Sun Jan 22, 2006 10:24 pm
sweetwilliam wrote:Where is the best place to ground the cathodes of power tubes?
As Flames already mentioned usually is working w/o problems. But the theoretical best place would be together with the rectifier's and first filter cap's ground.
Larry
