Can anyone help locate the NFB circuit on this amp?
tone?
Post by tone? » Tue Oct 15, 2013 4:24 pm
here is a guy shot
the Impedance switch is on the top right hand corner
http://www.flickr.com/photos/21189903@N ... otostream/
I want to locate the resistor so i can jumper it or change it to make the amp looser and a tad harier
thanks!
mightymike
Re: Can anyone help locate the NFB circuit on this amp?
Post by mightymike » Tue Oct 15, 2013 8:51 pm
I can't mak3 heads or tails from that pic, but I'm sure if you asked VHT which resister is the NFB that they would tell you. It's not like they covered it in goup. They might even send you a schematic.
Where's the presence pot?
tone?
Post by tone? » Tue Oct 15, 2013 11:44 pm
here is the presence pot on the left and reverb on the right
mightymike
Post by mightymike » Wed Oct 16, 2013 12:14 am
See that purple wire going under the board? That's prob your Nfb wire. I would look under to see that it is going to that pot. I bet it is. Unbolt the pots from the chasis if you have to. What ever long wire is going there to the imp switch or speaker jack (Usually purple) will be it. Then look for a resister between 27k up to 100k along that wire in series with it. That yellow box on the board behind the pot is prob a .68uf.
That's a 70s style Marshall presence circuit like this
http://img687.imageshack.us/img687/5231 ... d04par.jpg" onclick="window.open(this.href);return false;
Where's your speaker jack?
tone?
Post by tone? » Wed Oct 16, 2013 1:49 am
on the other side
I have the impedance switch circled in Red and next to it are the speaker jacks.
here is a high res
stef
Post by stef » Wed Oct 16, 2013 10:55 pm
It's a bad idea to mess with this motherboard :shock:
tone?
Post by tone? » Wed Oct 16, 2013 11:29 pm
stef wrote:It's a bad idea to mess with this motherboard :shock:
yeah I know!!!
LOL
tone?
Post by tone? » Wed Oct 16, 2013 11:30 pm
Its like I learned a bit how to fix a bike and then decided I could mess with the space shuttle
LOL
mightymike
Post by mightymike » Thu Oct 17, 2013 10:02 pm
22k is an off value, but R1on the little board could be it. Need to unbolt the reverb and presence pot to turn them and the board over to check. I don't know why the NFB (purple wire) doesn't just go straight across to the speaker jacks or imp switch. It's a straight shot across. Must be something else going on for them to route it to the side
mightymike
Post by mightymike » Thu Oct 17, 2013 10:23 pm
Is there a variable negative feedback control on your amp? If there is I would imagine a 50k to 100k pot in series with that 22k. Then the wire from the pot going to the speaker jack or impedence switch which woulr explain the routing towards the control of the purple.
So I guess I should ask what all your controls say. Is there a reasonace control? That the purple wire goes to?
tone?
Post by tone? » Thu Oct 17, 2013 10:28 pm
The purple wire goes to the transformer ?
A grey wire goes to the impedance switch
tone?
Post by tone? » Thu Oct 17, 2013 10:33 pm
mightymike wrote:Is there a variable negative feedback control on your amp? If there is I would imagine a 50k to 100k pot in series with that 22k. Then the wire from the pot going to the speaker jack or impedence switch which woulr explain the routing towards the control of the purple.
Thanks for all your help mike !
No there is no resonance control
It has switches for class a or ab
Tube or ss recitfier
Next to the presence is the reverb , then gain , volume treble mids
Basic stuff
mightymike
Post by mightymike » Thu Oct 17, 2013 10:33 pm
Hmmm is there a depth control?
tone?
Post by tone? » Thu Oct 17, 2013 10:35 pm
The other resistor on that little board is 100k next to the 22k
But if you look at the other pic the purple wire goes outside the chassis towards the transformer
tone?
mightymike wrote:Hmmm is there a depth control?
Nope no depth
