peavey triple x high bias reading
- mrkrausman
This amp has bias test sockets in back. It has 6l6s mounted. When I put my meter in probes it measures 55v DC not millivolts. What is happening here? Thanks in advance.
Miss those Metro kits terrible!
Metro 50 Watt
1980 Marshall 2203 JMP MkII
Mojotone 4X12 Scumback H75 M75
Metro 50 Watt
- joey
Re: peavey triple x high bias reading
If memory serves me correctly from the last one I serviced a while back, that test point only reads the bias voltage applied to the grids of the output tubes, (-55v sounds about right, +55 depending on polarity of the probes) it doesn't indirectly measure plate current via the cathode like the typical 1ohm resistance method or a bias probe would. If you take out the output valves you will still measure the same thing. If you have a probe, just set it that way, or what ever your favorite bias method is. That test point was not meant for user serviceability though, as far as I remember that is.mrkrausman wrote:This amp has bias test sockets in back. It has 6l6s mounted. When I put my meter in probes it measures 55v DC not millivolts. What is happening here? Thanks in advance.
