Fender Twin reverb 1966(Blackface) BIAS ADJUSTING HELP!!
IsraelB
Post by IsraelB » Tue Aug 16, 2011 5:02 pm
Hello!
I just replace all tubes of my vintage 1966 twin reverb, DOES ANYBODY KNOWS What M.A should i set the amp and what amperex per tube???
Or please tell me how to do it if im wrong!
THANKSSSSSSS!!!!
Janglin_Jack
Re: Fender Twin reverb 1966(Blackface) BIAS ADJUSTING HELP!!
Post by Janglin_Jack » Tue Aug 16, 2011 5:26 pm
You want to set the bias at 70% of max plate dissipation. For a 6L6 I think the Max is 30w per tube so 70% is around 21w. You would have to measure your plate voltage and then based on that plate voltage.
There are some bias calculators our there that do the math for you. I think this is the equation:
Idle Current = (max plate dissipation / plate voltage) * .7 (70%). Anyhow, you can look up the steps on how to do it.
I think a safe number is around 30-35mA, but to be sure, you really need to measure the plate voltage, etc.
Mike
